Results 11 to 20 of 21
- Jun 2009
- 837
- Nov 2008
- 148
March 1st, 2011 11:17 AM #13
that's normal. fuel is being fed into a running engine, even when you don't step on the accelerator.
- Jun 2010
- 321
March 1st, 2011 01:27 PM #14sir! i find your post offending! may nakakatawa ba sa post ko? AH nag post ako dito para humanap ng solusyon sa problem ng car ko !
* all I know my car well enough at hindi siya dating ganito! pina check ko na sa mechanic hindi daw normal kasi talagang malakas ang hatak ng car kahit naka 5 gear, he tried adjusting the clutch still the problem persist...... normal naman daw ang idle 750 rpm..... delikado kasi ito lalo na pag may humiram ng di sanay baka maka disgrasya pa....... punta ko na lang sa casa wala kasing mechanic na magaling sa 4 cylinder gas car dito sa province ..update ko na lang ito pag ok na....
- Jun 2009
- 837
March 1st, 2011 08:59 PM #15well sir,my intention is not to offend you. but id like to point out na hinde ako tumatawa ng walang dahilan. however mababa kaligayahan ko so yun baka ang problema natin.
better take it nga sa casa. mayayaman ata taga province mo kaya wala training mekaniko jan sa very common 4 cylinder car. puro naka v6 o baka may naka w12 pa ata mga kabayan mo.
also, lending a car is delikado na at itself. miski top condition ang kotse hinde dapat basta basta pinapahiram. dahil kelangan talaga sanay ang tao sa kotse na drinadrive nia especially kung malalim o mababaw ang clutch.
yun lang po.
March 1st, 2011 09:20 PM #16
March 1st, 2011 09:26 PM #17
From standing start pag engage ng 4th or 5th Gear aandar na ng kusa without jerking?
March 1st, 2011 09:34 PM #18
- Jun 2010
- 321
March 2nd, 2011 01:22 PM #19*dcph172 so ano dahilan? paki sagot para naman matawa din ako di lang ikaw
*sir jmpet626 yup aandar siya from standing start pag engage sa 4th gear mag jjerk ng konti syempre pero pag timpla mo clutch with out pressing the gas pedal mag mmove siya kahit flat surface......
*sir desert fox from standing start engage ko sa 1st gear flat surface kusang aarangkada with out pressing the gas pedal walang jerking or hesitation ang makina mag ccruise 5kph from standing start 1st gear with out pressing the gas pedal... pag may momentum na nga kahit di ka na apak ng gas parang may cruise control normal naman ang idle at rpm nasa 750 to 1k ..
Traffic!
