may problem na naman ang esi ko kusang tumatakbo kahit di pa naka apak sa gas lahat ng gear 1,2,3,4,5 at reverse parang automatic trans. normal idle naman ano na naman kaya problem?![]()
hindi ba kusa naman talaga umaandar ang sasakyan kapag ni release ang clutch?unless kung uphill sya.
it is normal for a MT to move to a certain speed if you are in 1st, 2nd, and perhaps 3rd gear evenif you are not pressing the gas pedal. my 90 lancer did that, my 2001 civic, did that, and my 2011 civic is also doing that... they are all MT...
but i highly doubt your engine will still be running if you are on the 4rth or 5th gear, since there's not much juice to sustain the minimum rpm for the engine to run. but if your claim on the 4th and 5th gear the engine is still running at 5 kph, then your idle might be too high. better have the ecu checked.
pag bitaw ng clutch tatakbo na ang car kahit di nag apak sa gas that means sa idle palang the engine has enough power to make the car go
kung hindi ganyan dati that means tumaas ang idling
Check first your rpm if still 800rpm-900rpm.Tama aandar talaga yan kahit normal rpm mo pero if mas mataas dyan mga 1000-2000rpm rinig naman sa makina tatakbo talaga yan kahit di mo aapakan pedal
first of all sir aandar talaga kapag naka-release ang clutch, now the one you stated na 5kph, tingnan mo yung RPM mo sa idle, kung mataas ang idling aandar ka talaga ng ganung speed. at startup nasa ganyan din ang speed ko dahil mataas pa ang menor habang nagpapainit ang makina.
From standing start pag engage ng 4th or 5th Gear aandar na ng kusa without jerking?
*dcph172 so ano dahilan? paki sagot para naman matawa din ako di lang ikaw
*sir jmpet626 yup aandar siya from standing start pag engage sa 4th gear mag jjerk ng konti syempre pero pag timpla mo clutch with out pressing the gas pedal mag mmove siya kahit flat surface......
*sir desert fox from standing start engage ko sa 1st gear flat surface kusang aarangkada with out pressing the gas pedal walang jerking or hesitation ang makina mag ccruise 5kph from standing start 1st gear with out pressing the gas pedal... pag may momentum na nga kahit di ka na apak ng gas parang may cruise controlnormal naman ang idle at rpm nasa 750 to 1k ..
