Results 1 to 7 of 7
- Jun 2011
- 49
September 24th, 2011 04:32 PM #1can my bad condenser cause my car to overheat on traffic? considering that i have no problem with my aircon. my condenser was damage during my car accident few months ago. may yupi siya. Now I am experiencing overheating on traffic. 3/4 temperature gauge. I have my radiator overhauled, new thermostat, "rekta" fan. new lower and upper radiator hoses. I almost checked everthing until I thought of my condenser. Is there a possibility or connection of overheating with my condenser? PLEASE help!
September 24th, 2011 05:30 PM #2
what is your make, model and year of the car? what engine do you have? 3/4 on the gauge is not overheating yet. maybe your condenser fins are bent restricting airflow. if your car is a nissan, it usually has a bleeder screw or plug at the highest point in the coolant flow passage. if there are air pockets in the cooling system, it will display abnormally hotter indication at the gauge
September 24th, 2011 05:57 PM #3
just noticed it's a honda. check for bleeder screws and bleed the system. if after the accident and you had the car damage repaired and repainted, check if the condenser had been painted over
- Jun 2011
- 49
September 26th, 2011 08:49 AM #5
Condensers are heat exchangers and if they're hot, because of the damage, or inefficiency of your fans, then your compressor may be overworked to maintain your cabin temperature. I think it is prudent to have it checked bro as heat may not be dissipating fast, causing an abnormal increase in the engine bay temperature, IMO.
14.1K:tvcomedy:
- Jun 2011
- 49
September 26th, 2011 04:15 PM #6just to give you an idea sir. I drove my car from pangasinan to manila last night. from pangasinan to tarlac. I did not experience high temp. I run maximum of 110kph sometimes stop and go. But when I starts running at the sctex and i tried to drive fast like 120-130 kph for atleast 20 min. I did not encounter high temp but when I slow down the car then my temp gauge is rising. Ive checked my engine bay, talsik ang tubig palabas sa reservoir ko at puno pa ito. i opened my radiator mejo konti na tubig. I put some water to fill my radiator and then i drive again going to manila but with a maximum of 100kph. no overheating encountered. ano kaya prob car ko sir. yung condenser ko may tama kasi nabangga pero ok na ok naman aircon ko. please help. Napansin ko lng. bakit sabay nag ON and off rad fan and condenser fan ng car. I noticed everytime my aircon shuts off then both my rad fan and condenser fan will also switch off. its like my aircon controls both my fans. As far as I know, the car's thermoswitch should be the basis of my rad fan to switch on and off. right? and my condenser fan also relies on the aircon. What wrong with my civic ES.
- Sep 2011
- 22
September 27th, 2011 08:51 PM #7hi sir, baka makatulong po check nyo po ung engine thermostat baka hindi n po nag function,dapat po mag open ang thermostat pag n reach n nya ang heat temp.
step.1 observe mo po n start ang engine n wag mag open ng aircon,at antayin nyo po n gumana ng kusa ang radiator fan motor.
kapag gumana ang motor ng kusa ibig sabihin ok ang thermostat switch..
step.2 check nyo po ung thermostat..kung hindi nyo po alam tanggalin pa check nyo po s mikaniko yung thermostat. for safe..
My thoughts: Resale value is really about perception, and right now the perception is that a...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
