Results 1 to 8 of 8
- Jun 2008
- 50
October 31st, 2009 07:38 PM #1Ask ko lang po bakit yung ibang mga d15b engine na nskikita ko may nakalagay na vtec na markings, samantalang yung akin ang markings niya is vtec-e? Ano po ang difference? Nakalagay naman dun sa engine number code ko is d15b talaga o iba po? Nabili ko na po kasi siya na ganito... Thanks...
- Apr 2009
- 1,902
October 31st, 2009 08:22 PM #2Sir anong civic yan? VTI-s ba yan?
A typical JDM d15b would have vtec honda embossed sa black head cover ng makina..
If it's a vti-s, I think yan kasi yung d15b 3-stage. It has a two vtec implementations: vtec-e and wildcam...
If it's an ef,eg or ek (between 1998 and 2000 models), it's most likely a transplant, so you have to confirm if it's the d15b 3-stage...
- Jun 2009
- 44
November 1st, 2009 09:51 AM #3"e" stands for efficient...same as other vtec din po yan,"siguro" change engine yan ,ganyan kase yung nabili ko sa surplus shop nung nagpalit ako ng engine,okei naman yan,dependable yan(as for my experience)
- Jun 2008
- 50
November 1st, 2009 06:46 PM #4My car is and esi 93... Change engine po siya... So malamang anu po kaya to? Ordinary vtec or 3-stage po? Thanks... Ang indicated din po pala sa registration niya is d15b vtec... Salamat pong muli sa mga makakasagot...
- Apr 2009
- 1,902
November 1st, 2009 10:00 PM #5It's simple to tell if it's a d15b 3-stage.
One solenoid = jdm vtec, no vtec-e, not the 3-stage
Two solenoids = 3-stage, with vtec-e (e for economy?)
If it's a 3-stage, lucky you. I heard it's got better fuel economy.
By the way, saang markings ba yung sinasabi mo? You mean sa head cover?
- Jun 2008
- 50
November 2nd, 2009 10:34 AM #6Yes sir sa headcover po... VTEC-E ang nakalagay instead of a VTEC lang... Thanks for the inpuy sir... Will check later po...
November 2nd, 2009 11:36 AM #7
The VTEC-e is the fuel efficient version of the VTEC and was used on Civic VX models that were made to be fuel efficient. The VTEC activates at a lower rpm as opposed to the performance version VTEC. the goal being to give you better mileage rather than more horsepower. IIRC the power should be around 70-90hp, as opposed to the D15B with 130hp.
- Jun 2008
- 50
November 2nd, 2009 05:10 PM #8Thanks sir for the input, but according to this site 115hp po ang d15b vtec-e... http://everything2.com/title/VTEC-E... Sorry po noob talaga ako... Pero mukhang pang economy nga po talaga yung e... Mas ok na po ito kasi mataas ang presyo ng gasolina ngayon... Hehehe...
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
