Results 1 to 13 of 13
    Tanong ko lang kung magkano na yung original na timing belt for CRV gen 1? Wala kasi ako ideal kung magkano, sa cousin ko kasi yung auto nasa abroad kasi sya dadalin ko lang sa shop for repair. 79k na yata yung odo due na daw palitan. tension bearing, change oil retiming, ipapacheck ko na din mga oilseals and water pump para isang gawa na lang. Any idea? Thanks
    Apr 2008
    79k parang sobrang mahal ata yan
    tanong mo dito http://www.speedyfixph.com/index.html
    Jan 2009
    Quote Originally Posted by boy_tino View Post
    79k daw odo reading. ;)
    Apr 2008
    ahahahahay sorry namalik mata ako hahahahaha salamat
    Jan 2009
    Double post
    Jan 2009
    Triple post
    Jan 2009
    Quadruple post
    have 2nd or 3rd opinions from different service centre para maka siguro ka bro libre estimate naman
    May 2004
    Baka Timing Belt Replacement, Which includeds, Timing Belt, Tensioner and Idler Bearing, Crank and Cam Shaft Oil Seal and Water Pump. Tune up na din para sabay na lahat. Para hindi ka mahirapan. kung ako eto gagawin ko. I'll buy the parts sa Banawe then let a Reputable shop replace it for me. Parts
    1. Timing Belt - (Original)
    2. Crank and Camshaft oils Seal - (Original)
    3. Tensioner and Idler Bearing - Koyo
    4. Water Pump - GMB
    Orig parts sa casa mo na bilhin para sure then yung replacement sa Banawe na lang. Usually Php1500 ang charge for the labor. Speedlab and Speedyfix very ok.
    May 2007
    Sir,
    just replaced mine recently, casa price for orig parts are as follows:
    T.belt - 2,105
    camshaft oil seals(2pcs)- 404.00
    oil pump oil seal- 302.00
    oil pump o ring-79.00
    oil pan gasket- 1,124 - changed it na din to avoid leaks -brittle na kse ung luma
    replacement parts:
    Koyo tensioner bearing- 700.00
    gmb water pump- 1,500
    labor- 1,000 - done by a honda mechanic sa talyer nya sa house =)
CRV timing belt
