Results 1 to 20 of 26
    Hi Sir/Mam,
    plano ko po sana bumili ng 2nd hand na auto around 2003/2004 model. my nakita kong good offer na city idsi amonth others, pero nagdadalawang isip ako ksi mukhang magastos yun kotse na yun (unang una 8 ang sparkplug), sa mga nakaexperience na ng kotseng to eto po tanong ko.
    1. magkano ang cost maintenance nito sa isang taon?
    2. anu ano pyesa ang dapat pinapalitan?
    3. matibay po ba ang makina nito, or madalas nagkakaproblema?
    Maraming salamat po!!*
    Guys dagdag ko lang M/T yun balak kong bilhin. CVT din ba yun??
    Apr 2004
    costs will be low.
    medyo complicado lang ang palit ng spark plugs nyan, but it's a good car.
    at 80,000 km palit ka timing belt, water pump and thermostat. tanong ka over the phone sa casa kung magkano kasi paiba iba presyo nito.
    as soon as you get the car, baba mo lahat ng fluids. new radiator fluid, new oil, new brake fluid, new m/t fluid (use plain 10w-30 engine oil wag gear oil).
    tapos change brake pads.
    total cost will be less than 5k.
    you can also opt to change the spark plugs. buy the expensive, platinum tipped kinds so they last longer and you wont have to replace them as often. mahirap daw kasi tanggalin spark plugs nito... and you need 5, not just 4.
    Quote Originally Posted by voltscastillo View Post
    costs will be low.
    Wala po ito timing belt, timing chain gamit ng iDSI, dati nagpalit ako ng brakepads kasi halos 7 yrs. old na yung kotse pero pagtingin ko makapal pa pala yung original pads. 8 pcs po spark plugs nito not 5.
    Change oil, tune-up, aircon cleaning at palit gulong lang maintenance ko. Sa suspension wala pa napapalitan after 7 years nasira lang eh yung 2 fan sa radiator at condenser.
    Aug 2014
    Quote Originally Posted by agp View Post
    Revive ko lang yung thread nito. just bought a City i-DSI 2005 in Automatic. Just want to ask few things.
    1. What combination ng shock absorbers ang dapat as replacement? Fluid type? gas type? also the brands aside from the pricy KYB.
    2. How much Casa rate for CVTF replacement? or if the product is available outside CASA? brands etc etc.
    3. Since i-DSI engines uses timing chain & not timing belt, paano ang maintentance nun?
    4. Lastly, my City is 2005 model & i want to install foglights, problem is walang abang, walang bracket sa bumper so i assumed na designed talaga yung model na yun na walang foglights... yung sa Jazz na older model pwede ba yung foglights nun install sa City?
    Thanks
    Quote Originally Posted by page7fordoddie View Post
    Thanks
    1. i think KYBs are the best brand.... And it would be the most reliable one aside from the OEMs. On the choice between gas and fluid type shocks, it would depend on the following: (a) the type of shock your car originally has (b) if you would prefer a bit of a stiffer ride than your current one. Gas types are a bit of stiffer than fluids, although they are tolerable naman. Hindi naman nakakaasar and (c) if you prefer a bit more durability. Gas shocks are a bit more durable than fluids.
    2. no idea on the casa rates though.... but it can be done via Servitek...
    3. Maintenance of chains would require replacement of the tensioner at around 80k kms. Para makita na din yung condition ng chain kung dapat ng palitan, but normally, it would last almost a lifetime.
    4. Pwede siguro yun, depende sa installer.
    Quote Originally Posted by jetro2k5 View Post
    No.
    M/T's are M/T's. They're not CVT's
    Salamat sa mga advice ninyo. So wala pala kong magiging problem sa CVT, nagbabasa ako sa ibang thread may problema pa ata dun sa CVT. Anyways mga sir maiba lang ako, last nalang to. How much po ba ang used car nitong Honda City M/T 2nd owner?
    Salamat!!*
    Oct 2008
    as always, the price would depend on the state of the car, the maintenance done with it and the mileage.
    Oct 2003
    ^its the same. Fuel strainer set = fuel filter.
    Aug 2014
    Mga Sirs, ang stock size ng front door speakers ng City iDSI anong size? Thank you!
    Feb 2005
    Quote Originally Posted by zechs View Post
    Thanks sa replies mga sir!
    Nov 2015
    Hi Sir, planning to buy a 2ndhand city IDSI..kamusta po ang FC and is this a good buy?
    Jun 2005
    Quote Originally Posted by crohise123 View Post
    Kung manual, oo.
    Kung matic, may sakit ang cvt units. Mahal ipagawa kasi palit tranny
    Nov 2015
    since timing chain ang city mga sir mas tipid ba xa sa maintenance?
    Jun 2008
    Quote Originally Posted by sirkosero View Post
    Kung manual, oo.
    Kung last batch na idsi cvt tranny ok. Yan ang batch na cvtf na ang nilagay sa tranny, wala kmi problema sa 2005 idsi jazz. Naibenta sa relative till now problem free pa rin.
cost maintenance for 2003 HONDA City idsi
