Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Hi Sir/Mam,
    plano ko po sana bumili ng 2nd hand na auto around 2003/2004 model. my nakita kong good offer na city idsi amonth others, pero nagdadalawang isip ako ksi mukhang magastos yun kotse na yun (unang una 8 ang sparkplug), sa mga nakaexperience na ng kotseng to eto po tanong ko.
    1. magkano ang cost maintenance nito sa isang taon?
    2. anu ano pyesa ang dapat pinapalitan?
    3. matibay po ba ang makina nito, or madalas nagkakaproblema?
    Maraming salamat po!!*
    Guys dagdag ko lang M/T yun balak kong bilhin. CVT din ba yun??
    Apr 2004
    costs will be low.
    medyo complicado lang ang palit ng spark plugs nyan, but it's a good car.
    at 80,000 km palit ka timing belt, water pump and thermostat. tanong ka over the phone sa casa kung magkano kasi paiba iba presyo nito.
    as soon as you get the car, baba mo lahat ng fluids. new radiator fluid, new oil, new brake fluid, new m/t fluid (use plain 10w-30 engine oil wag gear oil).
    tapos change brake pads.
    total cost will be less than 5k.
    you can also opt to change the spark plugs. buy the expensive, platinum tipped kinds so they last longer and you wont have to replace them as often. mahirap daw kasi tanggalin spark plugs nito... and you need 5, not just 4.
    Quote Originally Posted by jetro2k5 View Post
    No.
    M/T's are M/T's. They're not CVT's
    Salamat sa mga advice ninyo. So wala pala kong magiging problem sa CVT, nagbabasa ako sa ibang thread may problema pa ata dun sa CVT. Anyways mga sir maiba lang ako, last nalang to. How much po ba ang used car nitong Honda City M/T 2nd owner?
    Salamat!!*
    Oct 2008
    as always, the price would depend on the state of the car, the maintenance done with it and the mileage.
    Quote Originally Posted by voltscastillo View Post
    costs will be low.
    Wala po ito timing belt, timing chain gamit ng iDSI, dati nagpalit ako ng brakepads kasi halos 7 yrs. old na yung kotse pero pagtingin ko makapal pa pala yung original pads. 8 pcs po spark plugs nito not 5.
    Change oil, tune-up, aircon cleaning at palit gulong lang maintenance ko. Sa suspension wala pa napapalitan after 7 years nasira lang eh yung 2 fan sa radiator at condenser.
    Aug 2014
    Quote Originally Posted by agp View Post
    Revive ko lang yung thread nito. just bought a City i-DSI 2005 in Automatic. Just want to ask few things.
    1. What combination ng shock absorbers ang dapat as replacement? Fluid type? gas type? also the brands aside from the pricy KYB.
    2. How much Casa rate for CVTF replacement? or if the product is available outside CASA? brands etc etc.
    3. Since i-DSI engines uses timing chain & not timing belt, paano ang maintentance nun?
    4. Lastly, my City is 2005 model & i want to install foglights, problem is walang abang, walang bracket sa bumper so i assumed na designed talaga yung model na yun na walang foglights... yung sa Jazz na older model pwede ba yung foglights nun install sa City?
    Thanks
    Quote Originally Posted by page7fordoddie View Post
    Thanks
    1. i think KYBs are the best brand.... And it would be the most reliable one aside from the OEMs. On the choice between gas and fluid type shocks, it would depend on the following: (a) the type of shock your car originally has (b) if you would prefer a bit of a stiffer ride than your current one. Gas types are a bit of stiffer than fluids, although they are tolerable naman. Hindi naman nakakaasar and (c) if you prefer a bit more durability. Gas shocks are a bit more durable than fluids.
    2. no idea on the casa rates though.... but it can be done via Servitek...
    3. Maintenance of chains would require replacement of the tensioner at around 80k kms. Para makita na din yung condition ng chain kung dapat ng palitan, but normally, it would last almost a lifetime.
    4. Pwede siguro yun, depende sa installer.
    Mar 2004
    I saw a couple of Honda CVTF jugs over at the Speedyfix office.
    So I assume they also offer CVTF replacements.
    Aug 2014
    Quote Originally Posted by 1D4LV View Post
    Thank you for your quick reply Sir.
    1. I'll go for Gas type KYB
    2. Hindi sila nagrereplace ng CVTF sa Servitek, Aguinaldo highway. wala daw sila nung product sa casa lang daw available the last time nag inquire ako sa kanila for my GF's City 2010.
    3. Will have it check ASAP
    4. Study muna if kasya nga yung pang Jazz, or will retrofit Raybrig yellow like what i did sa old car ko.
    Thanks again! =)
    Aug 2014
    padagdag po sa post...
    Just bought honda city 2004 idsi, bigla na lang namamatay ang makina and it seems walang fuel. after ilang minutes na pahinga start nanaman ulit.. pincheck ko na spark plugs and battery all is working fine.. sabi ng mechanic it might be the fuel pump.. ask ko lang po sana magkano fuel pump ngayon? or is there any other reason bakit ganun nangyayari?
    Thanks po sa mga reply...
    Mar 2004
    Quote Originally Posted by zygot_35 View Post
    The same thing happened to my iDSI years back. Turned out to be a clogged fuel filter.
    Aug 2014
    already sent to the mechanic and clogged filter nga daw... sad to say affected na ang fuel pump ko kaya pinalitan na rn...
    Thanks again! =)
    try mo din sa servitek alabang. may mga nakikita akong nagpapalit ng CVTF dun.
    Aug 2014
    Quote Originally Posted by ess View Post
    Thank you sir sa tip.
    Sorry kung dito lang sa thread ako na to nag tatanong, nahihirapan ako sa search function hindi ko makita particularly mga gusto ko inquire.
    1. Ano size ng stock front door speakers ng Honda City iDSI 2005?
    2. Nakita ko sa User manual na magkaiba yung sets of spark plugs ng iDSI engine. yung 4 sa cylinder head at iba yung 4 na set sa back area ng engine near the firewall. Pero nung nagpa 18 points check-up ako sa Servitek, nakita ko na pare pareho yung all 8 plugs & sabi nila na okay lang naman daw yun. To make sure, naghanap ako nung particular na NGK plugs based on user manual. sadly, bihira daw yun sa mga auto supply. - Okay lang ba na pare pareho ang all plugs?
    3. Isip pako...
    Salamats guys!
    Jul 2011
    sir, parehas lang ang plugs ng front set (4 pcs) and the back set (another 4 pcs) of an idsi engine,
    i have a car with the same idsi engine, ang plugs na nakaindicate sa manual is NGK bkr6e-11,
    forgot the denso counterpart.
    and hindi bihira sa auto supply yan sir.
    may chance pa nga na magiba pa takbo mo by running different set of plugs na naka kabit.
    Feb 2005
    Question: Iba pa ba ang "Fuel Strainer Set" sa Fuel Filter or is it just one and the same thing? It's the same tube like device, right?
    Sep 2013
    Quote Originally Posted by kotiko View Post
    Depende rin sa kotse. Some fuel pump assemblies have a fixed fuel strainer that requires cleaning from time to time, others have the removable type na strainer. Iba pa ang fuel filter dun sa in-tank fuel strainer.
    Oct 2003
    ^its the same. Fuel strainer set = fuel filter.
cost maintenance for 2003 HONDA City idsi
