Results 11 to 20 of 26
August 20th, 2014 06:30 PM #11
Thank you for your quick reply Sir.
1. I'll go for Gas type KYB
2. Hindi sila nagrereplace ng CVTF sa Servitek, Aguinaldo highway. wala daw sila nung product sa casa lang daw available the last time nag inquire ako sa kanila for my GF's City 2010.
3. Will have it check ASAP
4. Study muna if kasya nga yung pang Jazz, or will retrofit Raybrig yellow like what i did sa old car ko.
Thanks again! =)
- Aug 2014
- 4
August 31st, 2014 10:33 PM #12padagdag po sa post...
Just bought honda city 2004 idsi, bigla na lang namamatay ang makina and it seems walang fuel. after ilang minutes na pahinga start nanaman ulit.. pincheck ko na spark plugs and battery all is working fine.. sabi ng mechanic it might be the fuel pump.. ask ko lang po sana magkano fuel pump ngayon? or is there any other reason bakit ganun nangyayari?
Thanks po sa mga reply...
Tsikot Member Rank 3
- Mar 2004
- 2,053
September 1st, 2014 12:31 PM #13
- Aug 2014
- 4
September 3rd, 2014 05:22 PM #14already sent to the mechanic and clogged filter nga daw... sad to say affected na ang fuel pump ko kaya pinalitan na rn...
September 3rd, 2014 05:48 PM #15
September 5th, 2014 01:17 PM #16
Thank you sir sa tip.
Sorry kung dito lang sa thread ako na to nag tatanong, nahihirapan ako sa search function hindi ko makita particularly mga gusto ko inquire.
1. Ano size ng stock front door speakers ng Honda City iDSI 2005?
2. Nakita ko sa User manual na magkaiba yung sets of spark plugs ng iDSI engine. yung 4 sa cylinder head at iba yung 4 na set sa back area ng engine near the firewall. Pero nung nagpa 18 points check-up ako sa Servitek, nakita ko na pare pareho yung all 8 plugs & sabi nila na okay lang naman daw yun. To make sure, naghanap ako nung particular na NGK plugs based on user manual. sadly, bihira daw yun sa mga auto supply. - Okay lang ba na pare pareho ang all plugs?
3. Isip pako...
Salamats guys!
September 5th, 2014 05:32 PM #17
sir, parehas lang ang plugs ng front set (4 pcs) and the back set (another 4 pcs) of an idsi engine,
i have a car with the same idsi engine, ang plugs na nakaindicate sa manual is NGK bkr6e-11,
forgot the denso counterpart.
and hindi bihira sa auto supply yan sir.
may chance pa nga na magiba pa takbo mo by running different set of plugs na naka kabit.
September 5th, 2014 05:53 PM #18
Question: Iba pa ba ang "Fuel Strainer Set" sa Fuel Filter or is it just one and the same thing? It's the same tube like device, right?
- Sep 2013
- 168
September 5th, 2014 06:30 PM #19
Hi sir! Question lang po baka may idea kayo. 1994 GLXi Lancer Itlog 4G92 - about 10yrs na rin na...
LANCER Itlog (93-96) Owners - Please Post Here!
