Results 11 to 16 of 16
June 17th, 2019 01:02 PM #11
June 17th, 2019 02:09 PM #13
- 52,731
June 17th, 2019 09:37 PM #14but it may save him the trouble of posting questions like "how do i replace my busted tail light bulb?" and other DIY-able chores.
June 17th, 2019 11:38 PM #15
I am with the "stay on D" guys here. The only adjustment I see is learning the quirks of a CVT transmission. Like if accelerating, you just press on the gas continuously and it will stay in the power band for you. Unlike with regular A/T where you press on the gas, then let go slightly for it to shift early.
- Aug 2017
- 16
July 25th, 2019 04:54 PM #16Staying in D really is best, whatever the terrain. At this mode, the RPM won't suddenly spike up unlike in the other modes. It is also more efficient as eco-mode works in D. Since you don't need to pull the switch trigger between N and D, it is easy to free-wheel on downhills then pull back to D on the up-slope. Working with only these 2 removes room for confusion.
For sustained, high-speed downhill drives where I want some engine-brake assist, I sometimes switch to S, so long as I know I won't be pushing on the gas. I also only use S when I have to overtake surely and quickly. There has been no situation so far where I would prefer L.
high idle RPM at engine start
