Results 1 to 20 of 22
    Oct 2018
    slight kickbacks suck with its matching knocking sound ugh!!!! faqqqq
    anyways as some have mention.. it does stick out of center. was driving along nlex-sctex and it was veering slightly to the right.
    sana hindi busy sa Honda GH. Any recommended SA there for warranty checks?
    The steering DOES stick out of center!!! Akala ko ako lang!
    Ang straight sakin is the steering wheel shouldbe turned a wee bit to the left. If straight na straight, veers to the right nga din.
    Slight issue naman sakin, pero will have this checked sa CASA sa sixth month. Or would you guys suggest to have it checked ASAP?
    Quote Originally Posted by ironman06 View Post
    It's likely just off toe. Nothing a good alignment can't correct, sir. Delaying may show on tire wear.
    dropby your dealer. wala gaano tao hahaha.
    if i were you, id take it to your dealer. checking isnt expensive 10$ or so
    Oct 2018
    Thanks, Sirs! Will drop by this weekend. Ill provide an update
    Nov 2011
    *StockEngine
    Sorry forgot about the calling card.
    Anyway, napa check mo na EPS mo?
    *Ironman,
    Pina align ko din sakin kase fresh from casa off-centered din sakin eh.
    Dapat less than 1k KM odo for the alignment warranty. Although green na sa report, di pa din centered, so pinatira ko sa Servitek.
    Manual adjustment na lang para gitnang gitna.
    Quote Originally Posted by TheUninvited View Post
    *StockEngine
    *Ironman,
    so far ok naman after adjustment. alao they checked kuno the eps and wala daw errors. iniiisp ko kung saan pwede ilong drive eh.
    Nov 2011
    Ahhh.. So walang sound yung sayo pag sagad? Kase once they hear it, no need for errors.
    And the EPS light won't turn on for this particular issue of the Civic FC.
    ah di ko pa natest full turn. ill test in a few...
Civic X (10th Gen) Steering Issues
