need help...sir ano kaya problema ng oto ko..ung RPM kc hindi pumipirmi sa 1000 khit d tumatakbo ang sasakyan ko...tapos parang umuugong ang tunog ng makina...nagpalit n ko ng ignition coil...carburator type ang honda ko...help me pls.
confi05,
please identify your vehicle completely. state model and date of manufacture, whether the car is a frankenstein (assembled of different components), repair history, last thing done to it, mileage and telltale signs and symptoms. the frequency, time of day, duration when all these symptoms occur. check the basics first using your owner's manual.
jick
certified auto
guam
kahit hindi ako naka aircon nagtataas baba pa rin ang RPM ng oto ko...ang oto ko is honda civic 94 LX...ngayon lang e2 nagyari sa oto ko, dati ang ganda ng takbo walang problema...
confi05,
the fluctuating engine speed is called hunting. if your car is carbureted, chances are either your idle speed adjustment is too low, your intake system has a vacuum leak or your PCV valve is stuck open. you may also check your carburetor for gum and varnish buildup. if your carburetor is dusted from absence of or has dirty air filter, you might consider cleaning the carburetor with a "carburetor spray cleaner". follow the instructions on the can. but try not to run the engine while spraying, in some cases the engine caught fire from stray high voltage from the ignition system. clean the carb throat as well as the linkages outside the carburetor. one spray can should be enough.
jick
guam community college
Do yourself a favor and go to Kamias/Kamuning road in QC.
Maraming Carb cleaning/tuning experts dun.![]()
go to A & M Carburetor specialist sa kamuning, hanapin mo si elmer. From edsa, nasa left side mo yun. dapat maaga ka, 8 am, kasi mabilis mapuno yung lugar.
baka nga cleaning lang yan, nangyari na yan sa kotse ng tito ko. test mo muna un. mura lang naman palinis.
thanks to all of your advise.... bka nga carburetor lang.. kya ipapalinis ko na muna... mga magkano kya ang "carburetor spray cleaner"?
bro mas maganda palinis mo na muna gaya ng sabi nila punta ka sa kamuning maraming shop doon na gumagawa ng carburator,
Wag ka nang bumili ng carb cleaner spray kasi yung dumi pag spray mo mawawala ng sa paningin mo pero tinulak mo lang sa loob ang mga dumi lalo mo lang pinapasok, baka lalong magkaproblema ang ride mo, gusto mo ba yun?
bumili ko ng carburetor spray cleaner pero parang wlang nabago...bkit ganon? parang naghihingalo p rin ung oto ko....
Hi to all,
This is also happening to my friends 1997 Honda Civic when the car is in "D" and "P". What could be causing this?
I told him to bring his car to a shop and have the car "throttle body" cleaned by a mechanic but I'm not really sure if it can fix the problem![]()
^pwede rin iyan ang cause. pero pa-sabay mo na din palinis sa kanya ang iacv ng civic niya. ganyan din sa akin dati. he could do it diy style or have it serviced at speedyfix or forcedspeed if he lives in the north (or any other reputable shops in his area)
hi,
i am not sure if anyone experiences this same problem. i have a 97 city mt.. my rpm is okay, i say 90% of the time.. kaya lang, there are instances wherein babagsak nalang ung rpm ko ng sobrang baba to the point na halos mamamatay na makina ko, siguro nasa 100rpm lang..this only last for about a few seconds, probably 10-15 seconds lang... it does not happen all the time.. it happens whether naka aircon ako or not..
for example, tumatakbo lang ako ng normal then i come to a full stop, that's the time na bigla nalang babagsak rpm ko.. so minsan kapag bumper to bumper or pag magbabayad ng toll... do you guys have an idea on this case? i don't experience this everyday... may mga certain times lang talaga.. thanks!ü
same prob with my old esi.. i just had my carburetor serviced ayun ok na siya
i hope this could help you guys, here are some additional information.
if the idle is low your throttle body need some clean up or you can adjust the screw for the idle to goes up.
if the idling is not stable check the spark plugs.
