Results 1 to 4 of 4
- Nov 2008
- 18
June 14th, 2009 07:49 PM #1Any idea magkano na ngayon magpa change engine esi ph16 stock to d15b vtec recently kasi nag inquire ako jan sa evang aroung Php26K not including tranny di ko pa nga naitanong kung kasama yung other peripherals such as altrnator, starter, power steering pump, etc., can anyone tell magkano na kaya ngayon ang d15b na vtec. TIA! Morehorsepower!!!
- Apr 2008
- 537
June 14th, 2009 08:50 PM #2D15b vtec from EG hatchback (same as ESi on front face) 30k to 35k including ECU (computer box), engine wire harness and tranny (manual or matic).
teka sir may problema na ba ng malaki ang makina mo na PH16?
June 15th, 2009 01:08 PM #3
yeah, spend half the amount mentioned above for total engine replacement on regular maintenance and tuning you can get nearly the same performance on your ph15.
- Jun 2009
- 3
June 16th, 2009 07:43 AM #4bro.. just for info..
i just got my engine changed also.. actually nsa talyer pa nga kotse ko eh..
for my 2 cents
Vti - B (economy) -----> 25k (kasama na lahat.. comp box, tranny, axels, starter.. basta lahat) *** ito ung pinakabit ko sa kotse ko
D15b ------>35k (kasama na din lahat)
B16 ------>90k ((kasama na din lahat)
+10k kung sakanila mo ipapakabit ung engine mo...
the shop is located in makati...
contact me if you would like to know more info.. if you want i can accompany you there..
here's my # 0927 467 9781
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
