Results 1 to 16 of 16
    May 2018
    Mga sirs, pa help ulit ung sskyn ko kpg ngsstart ako ayaw pmsok ng kuryente tpos ggwin ko steady lng mna ng konti tpos sstart ko ulit ayun na start engine na cia kaso mtagal nga lng ano kya problema nito. . .
    tpos kpg tumtakbo ang sskyn ung kuryente nwwla pro tmtkbo nmn cia paudlot udlot ung kuryente?
    Ang labo pero maraming pwedeng dahilan alternator, batt or hi tensor wire. Pa Check mo na lang sa actual na mekaniko since umaandar naman...dalhin mo na sa talyer
    May 2018
    bago battery sir kppalit lng. . nung sinukat ung battery 13.00
    Quote Originally Posted by Dancivic View Post
    kindly re-tell your tale again. it is difficult to understand.
    and please use all the keys. anghirap po basahin at intindihin ang mensahe ninyo.
    May 2018
    kpg sinusi ko ung sskyn ciempre iilaw cia hahayaan ko lng cia ng gnun cgro mga 3 mins kpg sinusi ko ulit ska cia aandar dti kc isng susie lng umaandar na mkina ngyon mghhntay pa po ko. . tpos kapg umaandar npo ung kuryente nawawala paunlot unlot pro naandar prn kaso nauutal ba
    i agree with spin.
    it would appear, that something needs to heat up a bit, or needs more time to move into position, for the contacts to work.
    consult an auto electrician, po, and be ready to spend lots of patience, time, and possibly... money. these intermittents do need considerable work to identify.
    it could be a simple relay replacement (cheap).. or the susian itself (ugh!)..
    May 2018
    i agree with spin.
    okay thanks. .
    Jan 2018
    Pacheck mo na sa electrician. Baka maayos ng grounding kit.
    Check your fuel pump as well.
    Saka libre naman yun pag type ng complete words, kumpletuhin mo naman ang hirap basahin ng ganyan.
    Quote Originally Posted by dancivic View Post
    mga sirs, pa help ulit ung sskyn ko kpg ngsstart ako ayaw pmsok ng kuryente tpos ggwin ko steady lng mna ng konti tpos sstart ko ulit ayun na start engine na cia kaso mtagal nga lng ano kya problema nito. . .
    Tpos kpg tumtakbo ang sskyn ung kuryente nwwla pro tmtkbo nmn cia paudlot udlot ung kuryente?
    MODERATOR'S WARNING: Text speak is not allowed
    May 2018
    noted . . . . . .
    Jan 2016
    TDC sensor...
    Feb 2009
    One at a time.
    First, change your keyboard
    Second, identify your engine
    Third, when did this concern start.
    Fourth, what was the last thing done to the car, e.g. refueled, prior to this symptom appearing.
    Fifth, is the malfunction indicator light on when the engine is running.
    Sixth, are there unusual noises, smells, vibrations when the engine runs.
    Seventh, what instrument lights are not behaving normally.
    Change your keyboard
    Jun 2005
    One at a time.
    The best solution to his problem really is to change his keyboard and write properly. Hirap intindihin ng problema nya
    Sent from my MI MAX 2 using Tapatalk
    Quote Originally Posted by sirkosero View Post
    millennials.
    we'll probably never place in the spelling bee now...
    Aug 2017
    Before you bring your car for repairs, I suggest you check these simple things 1st:
    1) Check if the 2 battery terminals are tightly attached
    2) check if the black, negative battery cable is tightly attached to the body of the car
    3) Check the fuses if all good and tightly attached
    I have 3 Grab drivers who complained about this only to find out items 1 and 2 are the problems
    Else, bring the car for check up to the nearest A/C shop as they always have an auto electrician... And cheap!
The car (honda civic dimension 2002) can't start engine until you wait for awhile.
