Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    May 2018
    MODERATOR'S WARNING: Text speak is not allowed
    noted . . . . . .
    Jan 2016
    TDC sensor...
    Feb 2009
    One at a time.
    First, change your keyboard
    Second, identify your engine
    Third, when did this concern start.
    Fourth, what was the last thing done to the car, e.g. refueled, prior to this symptom appearing.
    Fifth, is the malfunction indicator light on when the engine is running.
    Sixth, are there unusual noises, smells, vibrations when the engine runs.
    Seventh, what instrument lights are not behaving normally.
    Change your keyboard
    Jun 2005
    One at a time.
    The best solution to his problem really is to change his keyboard and write properly. Hirap intindihin ng problema nya
    Sent from my MI MAX 2 using Tapatalk
    Quote Originally Posted by sirkosero View Post
    millennials.
    we'll probably never place in the spelling bee now...
    Aug 2017
    Quote Originally Posted by Dancivic View Post
    Mga sirs, pa help ulit ung sskyn ko kpg ngsstart ako ayaw pmsok ng kuryente tpos ggwin ko steady lng mna ng konti tpos sstart ko ulit ayun na start engine na cia kaso mtagal nga lng ano kya problema nito. . .
    tpos kpg tumtakbo ang sskyn ung kuryente nwwla pro tmtkbo nmn cia paudlot udlot ung kuryente?
    Before you bring your car for repairs, I suggest you check these simple things 1st:
    1) Check if the 2 battery terminals are tightly attached
    2) check if the black, negative battery cable is tightly attached to the body of the car
    3) Check the fuses if all good and tightly attached
    I have 3 Grab drivers who complained about this only to find out items 1 and 2 are the problems
    Else, bring the car for check up to the nearest A/C shop as they always have an auto electrician... And cheap!
The car (honda civic dimension 2002) can't start engine until you wait for awhile.
