Results 41 to 50 of 60
- Jan 2008
- 4,726
January 21st, 2018 07:37 AM #41
- Jul 2013
- 2,450
- 54,206
January 21st, 2018 09:59 AM #43the air isn't sucked out in the traditional manual method.
the air is gradually pushed into and thru the brake lines, exiting out via the bleeder nipples, by the traditional "tapak.. bitaw.." process that every other tsikoteer worth his rear view mirror, has experienced.
brake bleeder nipple is opened, and mechanic shouts "tapak". the assistant (you! heh heh.) step on and floor the brake pedal, and the fluid from the brake master cylinder is pushed into the brake line. whatever air is in front of it, is pushed into the line.
"bitaw". the brake master cylinder spring pushes the piston back, allowing fluid from the reservoir above to fill up the cylinder.
"tapak". this new fluid is pushed into the brake line, further pushing the air downward.
the process goes on and on, until the mechanic sees that no more air, but brake fluid, exits from the bleeder nipple.
then he goes on to the next wheel and starts all over again, until all four wheels' brake slave cylinders are bled.
all thruout, someone keeps an eye on the reservoir, making sure it is topped up when the level gets low. if it gets too low and is emptied, air is re-introduced into the system, and the entire process must be repeated.
the entire process can be fast. 15-30 minutes.
filling the master with fluid on the bench, or when already bolted in place? it's a matter of choice, in my opinion.
but... if it is already full of fluid and some spill out onto the paintjob while bolting it in place...
btw,
you should do something about that ruined paint on your brake booster. baka kalawangin at ma-butas.Last edited by dr. d; January 21st, 2018 at 10:18 AM.
- Apr 2016
- 203
January 21st, 2018 11:15 AM #44Before the assistant bitaw the pedal.. dapat I-close yun bleed valve right? So it won't suck in the liquid it releases to the bottle? Kasi I'm reading some where they need to close the valve before releasing the brake.. pero parang some don't...
Here it needs to be closed:
How does a brake bleeder screw work?
"The bleeding process basically involves applying brake pressure, slightly loosening the screw - about 1/4 of a turn - to raise the end of the screw and allow air and fluid to flow into the hole at the bottom, through the screw and out the hole at the top. The screw is then tightened again and the brake lever released, drawing in more fluid from the reservoir and the process repeated until there is no more air left in the system. "
About Bench Bleed.. it is really very important:
see is bench bleeding necessary? - Honda-Tech - Honda Forum Discussion
"you don't have to bench bleed, but but there's alot of air which gets trapped in the MC if you don't bench bleed it 1st; plus you'll go through 2-3 bottles of brake fluid if you don't bench bleed it (without bench bleeding it will seem like no matter how much you bleed all 4 corners, they'll def be air with bubbles in your brake system & seem like it'll never **** pure fluid into the bottle). "
Tomorrow to whatever service center I visit. I want to make sure they did bench bleed and close the valve before every pedal release.. but is there variation where it doesn't need to be released?
I just had so bad experience the other day with service center where all the mechanic don't know how to flush steering fluid. He never did it since 2011.. doesn't know how daw.. and he is training about 5 apprentices in his shop.. wanna make sure I won't encounter one like him again...
- Jun 2005
- 3,774
January 21st, 2018 12:25 PM #45Ang mali ni TS dito, wala sya alam sa preno pero ang dating nagmamarunong sa mekaniko.
Napansin ko lang ha... No issue to pay 12-15k sa casa kahit mahal pero namamahalan sya sa 6500 part +30% handling fee ng casa kung sa kanila ipainstall. Ano nga ba total ng 6500 + 30%? Abot ba ng higit 15k para mamahalan? Labo lang.
Lost in translation kayo dyan. Sa mekaniko, di nila alam na yng bleeding na ginagawa nila sa master is yung bench bleeding na tinutukoy mo. Parepareho sa kanila yan.
After mo pa din namam ipagawa ang brake master mo, ibebleed pa din nila dapat all 4 corners ng sasakyan hanggang maging firm ang pedal.
Sent from my MI MAX 2 using Tapatalk
- Apr 2016
- 203
January 21st, 2018 12:26 PM #46I called up different service centers kanina.. some use hose in the bleed valve/nipple.. while some don't use any hose and bottles (for example Car Zone)...
Tanong.. if walang hose and bottles and gusto ko matanggal old black brake fluid.. paano matanggal? ipa drop lang yun old fluid sa floor from bleed/valve/nipple? Won't it hit any metal parts and cause corrosive reaction?
Also the technique where one opens and closes the valve for every pedal press is called 2 man method.. the one where you don't open and close the valve is called one man method.. ano mas effective.. ano usually ginagawa nyo?
I want to see to it tama gawin bukas.. kasi in the case of my steering fluid replacement at the corner of 14th st and Gilmore the other day.. hindi magalaw steering wheel for 10 minutes.. nagulat nga yun mechanico sabi nya baka sira na pump.. at nagulat rin ako kasi cost ng pump ay 30k.. pero after 25 minutes gumalaw naman steering wheel after he tried all sorts of combination... want to make sure hindi ulit mangyari bukas.
Salamat sa mga advices nyo.
January 21st, 2018 12:29 PM #47
I make it a point to have my car underwashed everytime I have any fluids changed.
Sent from my SM-T705 using Tsikot Forums mobile app
- Apr 2016
- 203
January 21st, 2018 12:58 PM #48
Itong shop na ito. They don't know how to flush old black steering fluid. The technician head said he doesn't do it since started working in 2001. That's why black pa rin steering fluid ko now and have to flush it bukas. Before I got the car serviced.. i thought lahat na mechanico alam paano. Then i asked him how he bleeds brake fluid.. he said he just use basin at the floor when changing calipers. He said air will automaticaly go out when using. So bleeding is foreign concept to him and he blames pedal softness to the replacement brake master part used (because not original daw).
If you will pass by the street anytime and see the shop. Just drop by and ask if they can flush your black steering fluid. They will tell you they don't do that and don't know how.
So this experience makes me realize some mechanico doesn't know the basic like flushing old liquid.
That's why tomorrow i'll have to ask every process they will make in the bleeding of the break fluid after i find a service center with hose, bottles and knowledge to do this (car zone doesn't use hose, bottles because they don't have time to go to each wheel at details.. they just release the air at the bleed valve and if meron liquid.. close na.. so can't remove the microbubbles that can only happen when you use hose, bottles.. ) So all the tips you all shared will be useful as I make sure tama process gawin bukas. That's all I want. Really thanks a lot. About not paying 30% at Honda.. eh.. if one can save 5k.. why not diba.. they charge 1900 for brake master replacement plus about 5k for the surcharge of using parts bought outside casa.
- Apr 2016
- 203
January 21st, 2018 01:30 PM #49I called up one of the shops recommended by Stockengine.. so far they have hose and bottles naman for the bleed nipple/valve.. problem is.. they don't have any hose for bench bleeding the master cylinder.. saan ba maka bili nito locally?
sino sa inyo mai extra ganyan?? I need them to bench bleed my brake master.
In case wala ako mahanap.. how do you bench bleed your brake master without using any hose to feedback on the reservoir.. please share your method that can successfully remove all air in the cylinder before you connect it to the car.. thanks!
- 54,206
January 21st, 2018 08:03 PM #50some mechanics get irritated, when a total stranger comes around and asks question after question. i'd get irritated, too, if this stranger even hints that what i am explaining out of the goodness of my heart, is incorrect. i mean, i am here in the shop, to make a living, not to teach.
TS might not be hearing what he wants to hear from the mechanic, but that does not mean the mechanic is doing it wrong. perhaps he is doing it right, but he just can not explain it well enough. but that's fine with me. i pay him for what his hands do.
videos of how to bleed brakes or power steering systems, are plentiful in the internet. i am sure these audio-visual presentations will prove to be more effective than my monologue here. i am sure TS can easily download a few of them, to view over and over again, until he "understands it right".
good luck, po.
i hope casa allows you to stand by as they service your vehicle. observing mechanics at work, is always an educational endeavor.
btw, be mindful of the pedal free play.Last edited by dr. d; January 21st, 2018 at 08:20 PM.
So it's another case of "pwede na iyan" once again. It's that kind of thinking that will put...
