Results 1 to 10 of 12
- Apr 2015
- 28
June 25th, 2015 04:06 PM #1Pa compute naman ako sir kung magkano abutin nito + labor:
Overhaul head gasket - sabi kasi ng pinsan kong mekaniko loose na yun thread.
^ Epekto ba ng leaking gasket yun pag bbrown ng tubig sa reservoir?
Ibalik thermostat, thermoswitch
Yan yun nakita kong problema nya ngayon. Di ko lang talaga matake yun stress na binibigay.
June 25th, 2015 04:23 PM #2
overhaul, around 15k.
thermostat around 3k
thermoswitch around 3k.
yes, epekto ng gasket yung pag brown ng tubig....
sama mo na rin kaya radiator overhaul, para malinis yung cooling system.
- Apr 2015
- 28
June 25th, 2015 04:40 PM #3General overhaul ba kapag gasket lang problema?
Sabi kasi nun mekaniko ko ipapamachine shop na yun kasi loose na daw yun thread.
Parang may nakikita din kasi akong leak sa makina pero di naman grabe.
Sa thermostat and switch gusto ko lang ibalik yun kasi ayaw ko na ng nakarekta fan.
Subukan ko muna ipagawa yun makina bago ako mag palit para maiwasan mag overheat.
June 25th, 2015 04:53 PM #4
yup, general overhaul since may leak na din naman eh..... make the budget around 20-22k for this including machine shop.
- Oct 2009
- 2,271
June 25th, 2015 04:54 PM #5sa akin kung top overhaul .gasket 1k good quality na.
sigurado i rethread ung block mo.mabuti kung makuha sa tap. i oversize ung bolt na gagamitin at isalang sa machine shop ung head para lakihan ung butas ng turnilyo.
gayak ka siguro arround 15k lahat lahat na yan..
- Apr 2015
- 28
June 25th, 2015 05:07 PM #6Ano ba signs na kailangan na ioverhaul yun makina?
Malaki laki din pala magastos ko pag pinagawa ko to.
June 25th, 2015 05:16 PM #7
Signs:
a. engine knocking
b. excessive smoke
c. burning oil
d. compression loss
e. high fuel consumption
f. power loss
g. overheating
h. dirty/muddy/oily radiator and reservoir.
Signs:
a. engine knocking
b. excessive smoke
c. burning oil
d. compression loss
f. power loss
g. overheating
- Apr 2015
- 28
June 25th, 2015 05:41 PM #8sa lahat ng nasabi yun brownish color lang sa reservoir yun nakita ko.
overheating kasi medyo malabo kasi nakarekta fan ako.
June 25th, 2015 05:42 PM #9
June 25th, 2015 05:47 PM #10
other signs:
a. rough running
b. oil sludge
but since ang sabi mo is yung radiator mo is medyo brown, it is a sign of a blown head gasket. baka kayanin ng top overhaul lang.... get siguro a second opinion on the valve threads, since sabi mo wala namang knocking sound.
pag na top overhaul yan and nabuksan, that is the time na makikita na may mga kailangan ayusin pa.
The CHAdeMO plug is definitely a concern. And yes, you are potentially purchasing old tech. In...
2021 Nissan Leaf
