Results 1 to 2 of 2
    Sep 2011
    Mga masters ano po kaya sira nung transmission ko, bigla nalang ayaw mg shift ng gear lagi lang sa 1st gear pag nggas po kau tumataas lang po ung rpm, at bigla nalang din po hindi gumana ung speedometer, dati po nangyari n po un tapos nung ginamit ko ok n naman peo po ngyon ayaw n po bumalik sa dati, nagsearch po ako hindi nmn daw po porket cra ung speed censor hindi n po magshift ung gear sana po matulungan nyo po ako, gusto ko po malamn kung sa electrical po kaya un o sa transmission, sana matulungan nyo po ako maraming salamat po
    [SIZE="4"]REMINDER: do not post messages in SMS/TXT shortcut format.
    Read the rules.
    (Also if your message is easier to read, more people will read and might even have the answer you need.)
    Ignorance of the rules is not an excuse.
    Repeat offenses will lead to banning.
    [/SIZE]
b18c engine automatic transmission ayaw po magshift ng gear, pls help mga masters
