Results 11 to 20 of 261
- Aug 2006
- 73
December 9th, 2010 01:31 AM #11Bro, Ok kay Mel Casaba, I'm one of the satisfied customers nya. You may want to drop by at his shop, free checkup naman and sigurado ka naman sa gawa nya. Automatic Transmission expertise sya, well-rounded kumbaga, di lang sa transmission but most on mechanical problems on most type of vehicles.
Well, kung electronic-related ang problem mo, I can also refer you my electronic/auto-electrical technician ko who is also located in Cavite (particularly in Imus Palengke). Di rin taga sumingil, mura lang at may warranty din. Sya kasi ang nag-repair ng ECU ko and got his final say sa servo problem ko recently since nadedetect din nya kung may problem sa mga sensors. Free check-up din po sa kanya kaya don't hesitate to drop by at his shop. I remember din kasi noon, may intermittent problem din ako sa pag-start ng ESi Matic ko, noon kasi di ko pinapansin and I suspected baka nga fuel pump, until such time, di na mag-start ang oto ko and found out na may mga busted capacitors/ICs na pala ang ECU and main relay ko. Bago ko kasi napinpoint ang ECU and Relay problem, pna-checkup ko din sa isang Mekaniko na malapit lang sa akin noon at walang makitang problema kundi dun na mismo sa ECU ko. Kaya buti nalang nakita ko sa internet ang contact info nung technician at nagkataon tiga-rito lang sa Imus.
I would suggest bro, na magpa-checkup ka din muna sa technician ko and try to get his opinion. Then dumaan ka din kay Mel Casaba for a second opinion. Tutal parehas namang free checkup and magkalapit ang area. Mel Casaba's Shop is at Salitran, Dasma along Aguinaldo Hi-way din. OR pwedeng daanan mo muna si Mel Casaba then punta ka kay suking technician din if sensor-related and/or ECU problem ang diagnose nya.
eto nga pala ang contact info nung technician and ni Mel Casaba...kindly tell them nirefer ko sila sayo ha..(Ms. Fannie)
Rafael Bautista
SOR Electronics shop
Imus Palengke, Imus Cavite
Mobile: 0909-7172174
Mel Casaba
006 Auto Shop
Salitran, Dasma Cavite
Mobile: 0923-3396127
Goodluck and sana maayos ang oto mo. Update mo nalng kami.
Landline: 046-8502840
December 9th, 2010 10:07 AM #12
December 10th, 2010 07:15 AM #13
meron dyan autosupply shop sa imus pag galing ka ng lotus mall right turn ka sa aguinaldo after overpass nasa left side NAJ ang name ng shop....
December 10th, 2010 10:28 AM #14
December 10th, 2010 10:36 AM #15
December 10th, 2010 12:11 PM #16
December 10th, 2010 05:35 PM #17
- Aug 2006
- 73
December 10th, 2010 09:22 PM #18Hello po..bro, yung shop ni Rafael, is near Abad Grocery after ng Imus Palengke along that street lang din. Kilalang grocery shop yun sa may Imus. Yung shop nya is located dun sa bagong tayong building dun..basta bago sya dumating sa Abad grocery. Sya din makakpagsabi sayo ng parts if ever meron sya. Tutal libre naman ang checkup eh. Yung sa ECU/Relay problems ko noon, on the spot may mga pyesa sya like capacitors, ICs etc.
As for Mel Casaba, ok yun bro. Di ko naman yan irerefer sayo kundi ako sigurado at di subok. Kasi ako, I'm after for the quality service yet affordable and honest. Kaya yang 2 tao na nirerefer ko sayo, for sure di ka magsisisi.
Sa mga auto supply naman. YOu can buy at Dayson Auto Supply. Mas mura dyan as compared kina NAJ and Imus Truckline. Kindly call them up for their location pero malapit lang din sa may Imus, Palengke.
Dayson Auto Supply
046-4716560
If ever pupunta ka or tatwag ka kay Rafael and Mel, tell them that I referred you ha. Kasi tinutulungan ko din sila to build up their client-base since natuwa ako sa service nila and natulungan din nila ako.
Goodluck.
MS. FANNIE
- Aug 2006
- 73
December 10th, 2010 09:25 PM #19
December 13th, 2010 11:01 AM #20
Hi Ms. Fannie I've been there last saturday... ok naman so far
na meet ko si mel casaba. soft spoken at mukhang magaling...
well check nya some of my relays ... then change lahat ng fluids ... siya pa bumili ng oil/spark plug using his own ride... sa honda cavite malapit lang naman..... well may receipt naman...pati cvt fluids.. papalit narin me mga spark plugs...sa kanya
all in all he just ask me 500 petot... tulungan natin kasi ok naman mukhang mabait...
observation ko sa trabaho nya ok naman..... kaya lang wala pa silang mga lifters no para sana masilip maiigi yung mga pang- ilalim pero ok naman honda certified talaga sya.. thanks.
sabi niya, balak narin nya bumili ng scanner para mas madali ma-trace mga problema soon para sa mga ECU/sensors...then antay lang for lifters...pag nakaipon na...well tulungan din natin mabait eh...
check nya rin map sensor ko wala naman problema.... well observed ko din.
update ko lang hindi na yan celphone number nya nanakawan daw siya ng celphone..
eto na bago nya number 0932-433-32-41.
tawagan nyo na lang .....thanks.
Xiaomi E-Car
