Page 339 of 341 FirstFirst ... 239289329335336337338339340341 LastLast
Results 3,381 to 3,390 of 3405
    #3381
    Quote Originally Posted by enjay72 View Post
    Hi folks. Any suggestions or tips on how to clean car rims damaged by dog pee? Napabayaan kasi matagal di nalilinis kotse [emoji852]
    Sent from my SM-N986B using Tapatalk
    travs is right.
    it will get only worse.
    either you fix it now (re-paint) or wait until it is larger.
    Aug 2014
    #3382
    travs is right.
    thank you sirs. it already got worse.
    the tire was losing air gradually due to built-up residue on the inside of the rims due to dog pee. i thought there was a hole in the tire but there was none. the tire technician had to remove the residue using sandpaper.
    i am now thinking of just replacing the rims entirely. any suggestions where to get stock rims that are cheaper than casas?
    #3383
    ang OA naman na rims problem. unless na bengkong, pa inspect mo sa iba bro
    #3384
    take a chance on the aftermarket rims shops.
    marami kasing nagpapapalit ng kanilang stock rims for other designs, soon after the car leaves the dealer.
    try carousell.
    but kung isang piraso lang naman, consider having it re-painted.
    re-painting mags isn't difficult.
    good luck.
    Aug 2014
    #3385
    Will do thanks
    Aug 2014
    #3386
    try carousell.
    good luck.
    Thanks. Any shop suggestion who does repaint? Di kasi ako DIY. I'll check carousell. 2 rims ang pinagtripan ng dogs eh pangit na tignan.
    #3387
    ^ where's your location?
    promaster in qc and masterwheels in las pinas. those 2 i've heard do good work.
    Aug 2014
    #3388
    Thank you sir. Pasig ako. I will check promaster
    #3389
    malapit ka ba maybunga (SAA clinic?)
    Jan 2020
    #3390
    What are your other brake pad alternatives? Mine already squealing and need to replace(third time) a new one . I want to go for a change and a bit cheaper than the OEM this time.
All new 2014 Honda Jazz (3rd Gen)
