Results 1,221 to 1,230 of 3405
- Jun 2009
- 59
February 19th, 2015 07:17 PM #1221
- Jun 2009
- 59
February 19th, 2015 07:35 PM #1222Kung pwede sana i-edit yung thread, lahat ng picture ilagay sa unang page para makita agad ng mga aspiring buyer at dagdag inspirasyon sa gustong mag-setup ng jazz nila.
February 19th, 2015 07:44 PM #1223
Hello mga sir, im planning to buy a new car and im torn between jazz and city, ano po ba mga pros and cons ng 2014 jazz? And as per checking website ng honda PH, tama po ba na 150mm ang ground clearance ng jazz? Dto kase sa honda malaysia...135mm nakalagay specs sheet ng jazz. Dyan satin nkalagay sa honda ph site parehong 150mm ground clearance ng jazz and city, so ano po ang tama? Importante po kase para sakin ang ground clearance...mahirap po kase masyado mababa prone sa sayad tska ung garehe po kase namin eh medyo pataas. Salamat po sa mga mkakasagot :-)
February 19th, 2015 10:04 PM #1224
honda city e if you don't care about the added features
honda jazz vx if you want most of the features except the side and curtain airbags (this is my choice)
check hondaphil website meron sila promo low all-in and low monthly
- Mar 2014
- 901
February 20th, 2015 12:02 AM #1225Your concern is all about the ground clearance of a vehicle. Both city and jazz have both GC in our market, same with other brand, because it is applicable in our road conditions comparing it to the country you mentioned. What you may consider now is what suit your preference in a car. A sedan, a mid-size sedan or a sub compact sedan? If you truly prioritize the height of ground clearance in a vehicle because your driveway is steep, then try considering to look at some AUV or SUV which have a greater ground clearance. Like a CR-V, Adventure, and the like.
Sent from my Starmobile UP+ using Tapatalk.
February 20th, 2015 03:14 AM #1226
Thanks for the input sir rodetor, ground clerance is just one of my concerns...I got confused about your comment 'Both city and jazz have both GC in our market, same with other brand, because it is applicable in our road conditions comparing it to the country you mentioned'...pardon me but I don't get it sir, I know that both city and jazz have ground clearance for sure but what I'm asking po is the difference of ground clearance if there's any? Because as per honda ph site...both city and jazz have 150mm ground clearance while here in malaysia po jazz has 135mm while city has 165mm (as per the specs sheet na nakita ko dito)...just confirming which is correct.
I like both city and jazz po, im just weighing the pros and cons between the two. Bnew SUV are beyond my budget po so im not considering them for now, while AUV is not my type :-). I'm pretty sure that I will be getting either city or jazz...i just need to make up my mind which is suitable for me. My previous car is a sedan...so I really want to try hatch this time sana..and I really like to looks of the new jazz but im also hesitant about the limited trunk space of jazz. Thanks.
February 20th, 2015 07:17 AM #1227
If you need a bigger trunk space, then city. If not, then jazz. Malaki-laki din ang trunk ng jazz even though its a hatch.
February 20th, 2015 07:39 AM #1228
Thanks sir zechs, may idea ka ba sir kng mas mababa ground clearance ng jazz kesa city? Sayarin po ba lalo na sa mga medyo steep na pababa? May naka park kase na 2014 city and jazz dito parking ng condo po namin...pag tinitingnan ko jazz parang medyo mas mababa ground clearance nya compare sa city...di ko alam kung tama tingin ko or baka mababa lang tlaga tingnan ang jazz. Thanks!
Pahabol na question pa po pala, di ba comfy ung gitnang part ng rear seat ng jazz dahil masyado nkaangat? Naiisip ko lang baka kawawa pala uupo sa gitna pag tatlo sakay sa likod ng jazz kng totoo lalo na sa long drive.
Almost 1 month ko na ata pinagpipilian jazz and city, una city na napili ko...pero tuwing nakakakita or may dumadaan na jazz...wow ganda...bigla nanaman ako napapaisip...haha..pag jazz naman na plano ko kunin bigla ko maiisip ung mga factors tulad ng trunk size, uncomfy rear seats daw ng jazz and ung mababang ground clearance compare sa city...ang gulo ko(:-(. Sensya na po sa mga questions ko...ayoko lang kase magkamali or magsisi sa kukunin kong auto...5yrs ko din kase babayaran kaya pinag iisipan ko talaga.
February 20th, 2015 09:33 AM #1229
If in doubt, get the one you can afford. For the majority, there will always be a better or nicer car than what you currently own.
February 20th, 2015 10:13 AM #1230
Sir Walter, actually pasok naman po sa budget ko pareho...I will just get the E CVT sa city and V CVT sa jazz, I'm already satisfied with what these two variants have. Kung sa looks lang I think ill go for jazz, but naiisip ko lang (1) yung rear seat ng jazz na parang dito ko din ata nabasa na di daw comfy yung gitna dahil masyado nakaangat and another thing is (2) yung ground clearance ng jazz...not sure kung mas mababa gc ng jazz compare sa city...gusto ko lang malaman kung sayarin ba jazz compare sa city. I think I can already decide once masagot yung 2 questions ko. Maraming salamat po!
^ serpentine belt Pala nagpapa-work Ng water pump sa k20 engine. Salamat Naman at ayuz pa...
waterpump area may konting leak
