Quote Originally Posted by markygy View Post
Yes sir no worries. What you need to know is when you shift it to "S" from D is that the S mode will retain the gear that you are on. Meaning you will need to manually shift the gears either + up or - down. Pero sa tingin ko alam mo na ito, I just thought that it was wort mentioning.
Just to add, pag nasa S mode kayo and the sensor detects that you are to slow for the gear that you are on, it will automatically shifts down a gear for you. But it will not do the opposite. It will also not allow you to shift to a gear if the ECU detects that you are either to slow or to fast for the gear you are trying to shift to.
Thank you sir! Now i know...nagtry ako D to S sarap.iba hatak.pero nagtataka ako isang shift pa lang ginagawa ko nasa 4 Gear na.
**kwento lang din po ginamit ng erpat ko yung jazz papauntang Pangasinan gulat sya ganda daw. ang tulin. 140kph tas may nakasabay saya jazz din mas mabilis pa daw tantya na 150-160 pero di na nya sinubukan dahil apo mga kasama nya.
*** Ano po magandang car shampoo at ibang gamit na din sa paglilinis ng jazz natin?
