Results 1 to 2 of 2
- Sep 2007
- 68
June 15th, 2009 04:46 AM #1Hi mga co-tsikoteers,
just want to ask for info or advice. I have brought a 2001 honda civic vtec3 dimension body. I got it with tein coilover pero i am not using it in a race track and used only for 2/3x per week daily drive. sometimes going to the province (nueva ecija) na masama ang kalsada. want to put it back to stock suspension. Reason: for better ride comfort. tein is medyo matigas pa din kahit I adjusted the settings to soft. I see shocks na pang-2005 na for sale pero I called the owner at casa na iba daw shocks at springs nun dahil daw sa abs. Hindi po ba talaga pwede yung pang-2004/05 shocks and springs sa 2001 dimension 3 civic din. kasi parehas lang sila dimension 3. difference lang na tingin ko is rear disk brake for 2005. Parang same shock mountings pa din naman sila dahil same body. limited budget po kasi kaya not able to buy new shocks and springs. just looking for 2nd hand na good cond. pa.
Pasensiya na po at mahaba. try lang to explain it clearly sa inyo. info's or tips naman po na may vtec3 dimension.
salamat...
- Jun 2009
- 12
high idle RPM at engine start
