Results 1 to 7 of 7
    Jun 2010
    Just had my 03CRV's ball joint replaced. The mechanic did not disconnect the battery before taking out the abs sensors connection. After replacing the abs connectors, the ABS lights won't go off. Please help!
    ano lang. alisin mo lang yung battery sir. Mga overnight. tapos kabit mo na po sa umaga. Sana mawala iyan.
    Jun 2010
    Tnx for the suggestion. I'll try it tonight and let you know what happens. Tnx again.
    Jun 2010
    Tried removing the battery overnight. Wala, nandun pa rin yung orange light ng ABS. Subukin ko na dalin sa shop. Tnx uli.
    Aug 2008
    naku ingat ka pag naka-on baka anytime puwede ka sapukin nyan
    May 2007
    Quote Originally Posted by jeprox1925 View Post
    Did he clean the Sensor? Take your rag and wipe the sensor until its clean. I prefer not to use any chemicals on the sensor to avoid potential problems. If you need to, use mild soapy solution and rinse well. Reinstall the sensor in the same manner it was removed.
    kailangan mo jan scanner para ma pinpoint kung ano ang fault
ABS Lights on
