Results 11 to 20 of 31
August 6th, 2013 11:01 AM #11
noted sir, salamat...
anong meron sa mga med-rep na nakavios j?
in terms of fuel consumption hindi ba mas magastos manual kasi pag traffic naka uno or dos ka lang which actually consumes a lot of gas? uhrm sorry if the question seems dumb
August 6th, 2013 11:11 AM #12
Vios j kasi lahat manual. That's the preferred car ng pharmacy companies. Lahat manual kahit lalaki or babae you get the same.
Mas malakas matic sa gas kasi you loose a lot of power sa transmission unlike manual ikaw control ng lahat, from clutch to gear selection.
August 6th, 2013 11:59 AM #13
ohhhh i see.... sabi kasi nung sinasabayan kong nakavios j matigas clutch.
speaking of clutch how do i know kung my prob na yung kambyo ko? kasi parang hirap akong dalhin sia sa uno. akala ko d lang naapakan ng maayos yung clutch so tinest ko sia idos tres at kwatro kumakagat naman pero pag itataas ko ng uno ayaw ilang tries bago kumagat tapos parang antigas pa, sabi saken baka daw sobrang bilis ko nung nagtry ako mag uno pero hindi naman ako mabilis that time.
- Mar 2012
- 107
August 6th, 2013 12:26 PM #14pa try mo muna adjust yung sa clutch. pati reverse ba ganun din? nung nagka problema sa cluctch master ko ang primera pumapasok pero may sabit at medyo may grind din ang reverse.
August 6th, 2013 02:25 PM #15
August 6th, 2013 03:42 PM #16
wala naman ako problema pag nagrereverse gear ako yung uno lang talaga. >_< ano yung "grind" anak ng tilapya wala talaga ako alam sa sasakyan, driver lang kasi ako konting weird na tunog at pakiramdam sa sasakyan pasa agad.
try ko pacheck mga yan sa weekend sir... mura lang din ba paayos ng steering? >_< last month okay pa yung steering wheel tapos out of nowhere pawis steering naman na, ambigat kapag full steer ginagawa ko,.
August 6th, 2013 03:51 PM #17
Grind = tuning na parang naguutugan bakal.
Malamang ubos na power steering fluid. Check under the hood, may nakalagay naman dun na "power steering fluid" sa cap ng container. Kung walang Laman, malamang may tagas sa return hose or rack and pinion.
August 6th, 2013 04:04 PM #18
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
