Results 1 to 4 of 4
    Apr 2009
    post ko lang yung problema ng oto ng friend ko.pag nag reach sya ng 120kph tataas agad ang temp sa temperature gauge nya.pero pag tumigil sya hindi naman daw nuubusan ng tubig bubulwak lang yung tubig pag binuksan nya yung radiator cap.and recently lang pag naka on daw ang aircon nya tumataas na din daw yung temperature.ano kaya ang possible problem nito?
    Quote Originally Posted by mejo29 View Post
    Several things to check. Same thing din sa Civic ng wife ko.
    We replaced the radiator and water pump. Malamang barado yung radiator kaya hindi nagfloflow yung tubig at bumubulwak. Explanation, the water pump is driven by the timing belt. At low RPM water pressure is low, as the RPM goes up, so does the water pressure.
    We replaced the waterpump during a timing belt and tensioner change. When the water pump was checked, the impeller (yung blades sa loob) showed excessive corrosion.
    As for the aircon related overheating, another thing to watch out for is the aux fan.
    Apr 2011
    Dagdag lng din po. Kung bumubulwak ang tubig sa radiator with engine at idle, it could be a head gasket problem.
    Jun 2010
    pa overhaul mo muna rediator para malinis........... then observe
95 civic esi temperature problem
