Results 11 to 20 of 23
January 15th, 2010 10:07 AM #11
north american ES civics came with d17s, 1.7L 3 stage vtecs. i think the d16 came with the old EG, and was non-vtec.
i'm not a marketing man, but i think it makes sense to just declare the ES as 1.6 for tax reasons (equals lower sale price) even if its a 1.7L, than to create a new engine block for a specific market in southeast asia. besides, it's a natural progression... nung 90's every car manufacturer still marketed 1.3 and 1.5 engines, but honda already came out with 1.6. when the ES came out, it was 1.7L, and when the FD came out it was 1.8 minimum. other companies still churn out 1.6s.
i'm not 100% sure my ES has a 1.7, though... until i can see the engine block and measure the cylinders with a caliper.
back to topic: i've often wondered if the ES engine would fit into an EK. i doubt if the axles would fit, but to be honest, ang kailangan lang talaga jan oras, research at pera. VW beetles nga nilalagyan na ng b16 ngayon, civics pa kaya?
EG and ES have about the same space in the engine bay, so if you can plop down a d17 in there and the engine mounts line up, well, you're halfway done. remove the old harness and ECU, plug in the new one, and then start.
- Feb 2011
- 1
February 16th, 2011 04:14 PM #12Sir bago lng ako dito.. Nakabili ako ng makina na d15b 3stage sa banauwe. With complete harness and computer box. Pinalit ko sa ph16 sa esi. Anong rpm para mag 3stage ung makina.. Pls help po.. Tnx
- Apr 2009
- 1,902
February 16th, 2011 04:24 PM #13Nagpalit ka ng computer box sir?
AFAIK, OBDII P08 ang ECU ng D15B 3-stage.
Automatic naka VTEC-E mode (12-valve) yun on idle to low rpm.
Then VTEC-E disengages to use 16-valve mode with no VTEC on mid rpm.
Then you hit the VTEC range around 5000 rpm to activate the 20-camlobe mode, which gives you the VTEC yo kick.
- Jan 2004
- 3
September 16th, 2011 01:50 PM #14I am having my Esi Block work on a 3-Stage D15B head. there are several issues with this project though, still sorting it out. The ECU for the 3-stage engine is a P2J box, of which several sensors which are not present in the non-vtec Esi engine is now present. The stock P27 Esi ecu can run the engine after the swap, no vtec yet. Mechanically it is possible, but with engine management, as i have said, still sorting it out as of the moment.
September 16th, 2011 04:18 PM #15
September 18th, 2011 05:10 PM #16
- Jan 2004
- 3
September 19th, 2011 11:45 AM #17
September 19th, 2011 06:07 PM #18
- Oct 2012
- 7
October 7th, 2012 12:17 PM #19Hello Guys,
Newbie po and need your expert advices. Balak ko po palitan ung engine ng Honda Civic 98 LXI ko due to automatic transmission issue. Mas makakamura daw po kasi kung kasama na pati engine. Since may other issues din po kasi ako sa engine like idling and nauubusan lagi ng tubig, so I have decided to change the engine na din po. Ang question ko po e pwede ba sa kotse ko ung Stage 3 d15 na engine na binabanggit sa forum na to? Gusto ko kasi yung medyo malakas yung makina, VTEC, and fuel efficient which I heard na available sa engine na to.
Need your expertise po.
Thanks in advance!
- Apr 2009
- 1,902
October 9th, 2012 03:12 AM #20Yes sir swak ang D15B 3-stage VTEC sa ESi mo.
Bolt-on, no modifications needed.
does it mean no huge differences between ceramic vs crystalline ?
