Page 48 of 50 FirstFirst ... 3844454647484950 LastLast
Results 471 to 480 of 491
    Feb 2019
    #471
    I started the car and move it a bit forward then put it in P position. I went out of the car then press the remote but the door wont lock I check all doors but they are close. Then I went back inside and try to start the engine to my surprise engine wont start! I depress on the brake and turn the key on then it lights up then engine start. What had just happen? Has anyone encountered this with their honda?
    #472
    as a safety precaution, some cars won't lock using the remote, while the engine is running?
    also, some ATs won't start if the brake pedal isn't depressed?
    if the remote is factory,
    the warnings may be in the owner's manual.
    Feb 2019
    #473
    No the engine is not running because I already turned it off and the remote key is with me. Something might be interfering the remote key perhaps thats why it wont lock and then it wont start the engine either nornally it would start the engine no need to depress the brake pedal. This is strange.
    Feb 2019
    #474
    Seems like the car doesn't recognize the remote key because it cant remotely close the vehicle and even turn on the ignition. I check again today it is working normally just last night that suddenly happened.
    Feb 2019
    #475
    Saw this in shopee is this genuine honda type 2 blue coolant? the packaging is different and it has thai characters written on it.screenshot_2021-01-26-22-03-58.jpg
    Feb 2019
    #476
    Up! Any honda users here? Just want to top up my coolant reservoir.
    #477
    Just use distilled water until you decide to change the coolant.
    Feb 2019
    #478
    Okay that would be easy I thought coolant and distilled water cant be mix and Honda coolant is quite pricey compared with Toyota.
    #479
    what's the link? there's a seller there who's quite reputable. not sure if it's the same guy.
    Feb 2019
    #480
    You type in Honda Coolant Blue Type 2 and this will show up together with other sellers Coolant. This is cheaper a bit at Php650 others are selling it for around Php800 to Php1k but this one is honda coolant thailand and im not sure if this is genuine or same as the other Honda Coolant packaging.
2019 Honda Brio
