Page 310 of 311 FirstFirst ... 210260300306307308309310311 LastLast
Results 6,181 to 6,200 of 8838
    Dec 2014
    * cnc
    Parang yung mga bagong city lang ata from 2018?
    not sure kasi dun sa article na nabasa ko wala namang city sa list or maybe US article kaya hindi na nila sinaba city.
    Just checked kanina both lights not working
    IIRC it will lit pag engaged ang brakes? (Naka apak ka)
    Naka ilaw ba yan pag on ang park lights?
    Basta ayaw umilaw both sides.
    (Car not mine BTW ctto)
    i don't honda, but
    both lights affected at the same time?
    i'd check the rear light switch and the fuse.
    but, as unlikely as it may, i'd check the bulbs first. they're the easiest to check, kasi.
    good luck.
    Oks lang kung bulb lang problem pero baka puwede rin brake light switch.
    Feb 2010
    Changed full set of tires last weekend pero d nagawa camber/alignment cos the tie rod, rack end and stab link needs changing. Can anyone suggest/reco a good shop where to buy and any specific brand? TIA.
    safe ba yung Novsight na LED light sa city natin? may nabasa ako na need daw na may CANbus ang LED light na ikakabit dahil may masisira daw (forgot what it is hehe).
    Jul 2017
    Quote Originally Posted by Tha_Mann View Post
    novsight gamit ko sa high beam. since last year pa wala naman problema.
    Sent from my RNE-L22 using Tsikot Forums mobile app
    Mar 2018
    Good morning, question lang po for VX+ owners. Na-experience nyo na ba na bigla na lang umilaw yung VSA (traction control) warning light pag nalulubak? Wala lang, first time ko yata ito napansin and not sure if normal sya. Salamat.
    Jul 2017
    just want to ask kelangan ba talaga palitan ung cvt filter kapag nag palit ng fluid? and enough na ba 3.5L of cvtf?
    Quote Originally Posted by KcireReaver View Post
    drain and fill lng for below (100,000km/10yrs) but it has to be done every 24-30months
    Jul 2017
    more than 2 years na rin. bale first time palang magpalit. pero ung napanood sa yt kasi pinalitan rin ung filter nya kaya medyo nag aalangan ako
    low mileage bro, minimal metal yan.
    Twice na ako nagpalit CVTF (every 2 years) never pa ako quoted with filter replacement.
    Jul 2017
    4L ba talaga kelangan kasi ung nabili ko 3.5L lang. nag aalangan ako baka mabitin. hindi kasi ako makapunta sa ilocos dahil sa situation natin ngayon
    nasa owners manual 3.4-3.5L. just don't let them blow air thru the fill hole.
    Jul 2017
    ahh see. so tama lang pala talaga ung isang container ng 3.5L cvtf. nakaorder pa naman na ako ng isa pang litro just in case magkulang. anyway salamat sa tips and info mga sir. mas madami talaga sumasagot dito kesa sa HCCp page sa fb.
    Did you guys replace your CVTF Filter? Ano sched required replacement nun?
    tinanong ko yan sa dealer ko a few years back and sabi nila di daw usually pinapalitan as long as kaya pa linisin at hindi pa damaged
    i also asked the same question sa isang honda dealership nung nasa california ako and they said the same thing. any dealer however, would be willing to change it anytime you want, as long as you're willing to spend $$$
    btw, now lang ako nagbackread ng mahaba uli... nakadalawang beses ka na pala nahingi ng digital owner's manual - sorry
    https://cvws.icloud-content.com/B/AT...oS-90daCo&cd=i
    https://cvws.icloud-content.com/B/AW...yHJgRaQxc&cd=i
    https://cvws.icloud-content.com/B/AU...1ooWvzC7o&cd=i
    https://cvws.icloud-content.com/B/Ae...rTSI0zYig&cd=i
    https://cvws.icloud-content.com/B/AY...UUqR6T07M&cd=i
    https://cvws.icloud-content.com/B/AY...qwefbkvkQ&cd=i
    https://cvws.icloud-content.com/B/Af...ljEwEgjqw&cd=i
    https://cvws.icloud-content.com/B/AQ...VfByx3aX8&cd=i
    https://cvws.icloud-content.com/B/AQ...hMDAsycdw&cd=i
    Pretty reliable naman yung L15 engine ng Honda City. Kahit sa labas mo na pagawa yung change oil nyan, oks lang yan. You can use 5w30 or 0w20 FS oil and any suggested oil filter.
    Medyo pipiliin mo lang yung shop na gagawa ng CVTF change but straightforward lang din process nito.
    Oct 2015
    Mga sir sino na po nakapag try ng double contact ang turn signal ng gm6 natin? Gusto ko sanang sumabay sya sa switch ng park light. Thank you
2014 Honda City (Gen 4)
