Anu pong amaron battery model ang magandang ipalit for gm6? Para maka kuha ng idea and price.
Guys, how can I remove paint spatters on the hood.
if your paint is regularly shined with a "paint protectant", you might be able to remove these using polish.
"if the polish is thick enough, the cement may be sticking to the polish and not to the topcoat.
try ordinary water first, with loving fingers only.
and do it asap, before the paint cures.
^Thanks. Unfortunately, hindi alagang wax yung oto ko. Just your regular car wash using shampoo & water. Somebody recommended carnuba wax though. I'm ngonna try that this weekend.
Last Saturday umilaw check engine, nireset ko na lang by removing battery connections then kabit agad ulit.
Nawala naman, drove it. Nakauwi ng bahay, nung paalis ako umilaw nanaman.
Saturday night i removed again connections, overnight.
The next day buti open ang Honda Pasig kahit sunday, on my way hindi naman umilaw.
Turned off the engine talk to the SA, sabi niya if nireset ko wala daw makikita scanner.
Pinuntahan namin oto, pagka start naka ilaw nanaman.
Ang problem wala daw specialists pag Sunday, regular PMS lang daw sila. Pero baka meron din daw pumasok within the day.
So Hindi pala part ang PMS scanning?
Iwan or ibalik ko na lang daw, decided to go back home na lang.
Pauwi ako dalawa na umilaw:
(FYI Hindi sa handbrake yan)
Napraning na ako binalik ko ulit and iniwan na sa Honda Pasig.
Tinawagan ako lunchtime
Eto raw may problem:
Magagamit ko pa din naman daw and okay lang itakbo.
Still gusto ko kumuha 2nd opinion, if same sila diagnosis order na ako nung piyesa. (Kaso pano pag magkaiba diagnosis? 3rd opinion . . . . .)
Badtrip out of warranty na.
cooling and lubrication wala problem. fuel consumption & power lng ang problema
FOCUS
ito yun exact location based on the catalogue photo... make sure malamig makina.
How To Change O2 Sensor in a Honda Fit (2007) - YouTube
ito yun sensor test as per honda fit specs.
FOCUS
If you read it. Walang change oil sa 1K PMS.
Sa 6th month or 10K pms ang change oil
