Page 199 of 311 FirstFirst ... 99149189195196197198199200201202203209249299 ... LastLast
Results 3,961 to 3,980 of 8838
    Mar 2004
    Quote Originally Posted by ComboHits View Post
    Sirs, how much tyre pressure ang gamit nyo? Meron na po ba nakagamit ng steelmate tyre pressure monitors sa inyo? Baka may marecommend kau mabilhan. TIA
    There's a seller in *******
    Nasa driver door frame ang pressure sir
    Sent from my D6503 using Tapatalk
    Natuluyan na battery ko, nakarating pa ako office. Blessing in disguise na medyo bothered ako I went down the parking during lunch time ayun hindi na totally nag start.
    I called a friend yung uncle niya owns a battery shop nearby the office. Nagpadala ng tao may spare battery and jumper cables.
    Started the car and brought it sa shop for checking.
    Akala ko kasi baka grounded due to the installed Europas, yun pala deads na talaga battery. Car is not grounded, alternator is working perfectly.
    Gladly may diskarte yung installer, nagkabit ng spare battery prior removing the old one and installing the new one, hindi na nag reset City ko.
    Oct 2014
    Hindi mo napacheck sa casa bro? Un sakin pinasama ko na sa check nun pinasok ko which is sabi nun SA okay pa daw battery. Di ko sure kung reliable nga lang.
    Quote Originally Posted by vinrom View Post
    Wala eh body repairs lang talaga, nawala din sa isip ko. Eh 2 weeks din idle sa casa malamang yun ang nakasama. Takot ko lang baka sablay installation nung busina baka naging grounded.
    Warranty for the battery pala is 1 year or 20K KMs which ever comes first, kay motolite wala tayo warranty.
    May 2016
    Labas na daw ang 2017 Honda City. Yung E CVT version has fog lights.. Yung bibili pa lang, ask your SA about it, sayang din yung fog lights..
    Dec 2014
    CNS ano mileage mo? What do you mean by reset? like back to zero odo?
    guys na experience nyo na ba na meron malakas na parang "static sound" sa may driver side? parang radiation detector ang tunog e hahah lol
    ewan ko kahapon lang ng umaga nagkaroon ng ganun tapos nawawala naman sya
    Dec 2014
    Quote Originally Posted by poleng23 View Post
    Di lang ikaw nakaka experience nyan bro, sakit ata ng GM6.
    Try mo buksan pinto then sarado minsan dun nawawala. Depende ata sa pagkakasarado ng pinto
    ohh after 10mos ngayon ko lang sya narinig. ganun nga ginawa ko unlock-lock then bukas ng pinto sarado ulet ayun nawala. sakit sa tenga ng static sound na yun
    Static sound? O parang may medyo malakas na pumipitik na tunog pag nag aautomatic yung aircon?
    May na eexperience kasi akong parang "snap" na tunog at movement pag nag aautomatic yung aircon sa driver side hanggang sa flooring. pansin ko medyo noticeable lalo pag nasa labas ka.
    parang galing sa ac clutch compressor. wala naman langit-ngit, griniding or parang whistling sound na nangagaling dun sa mga belt at bearing, talagang pitik lang na medyo malakas pag nag aautomatic yung AC.
    25K Kms na bro, reset is mag re-learn ulit yung car. To add yung mga na set mo na settings sa systems reset din.
    Dec 2014
    Thanks CNS! Pa check ko na lang na lang battery ko sa casa sa July PMS ko.
    Anyway sino na nakapag 30k/18 months PMS? Magkano kaya mga sir?
    Im due on the 4th week. Curious too.
    Oct 2013
    Sinisingil ako ng casa (alabang) dito. Irereprogram pa daw nila yung ECU. Di daw pwede yung simpleng tanggal old battery and kabit new battery.
    Pero 2 months na ako nagpalit ng battery without having it reprogrammed, wala naman akong napansin na kakaiba sa kotse.
    Quote Originally Posted by Monte View Post
    Sabi ng owner's manual clock lang ang magrereset pag natanggal battery.
    Apr 2015
    Question regarding sa driving. Kapag stop and go, okay lang ba mag neutral then shift to drive kapag moving na? And kapag naka full-stop okay lang ba mag neutral then handbrake? Tama ba ung driving habit?
    Sent from my LG-H818 using Tsikot Forums mobile app
    Dec 2014
    Quote Originally Posted by lowiejee View Post
    Kapag stop and go D and brake lang ako.
    Pero pag bumper to bumper as in walang galawan or matagal pa mag green traffic light, I put it in N then handbrake.
    Not an expert sir pero base on what I read, if you always put it on N at then balik agad sa D sa stop and go situation, makakatipid ka nga ng gas pero wear and tear naman ng transmission ang affected.
    Pag matagalan naman na stop, like ppark ka sa tabi, may iniintay ka or may bibilhin ka sa tindihan, for safety purposes, always put it in P.
    Make it a habit also na tingin muna sa instrument panel kung what transmission are you in before bitawan ang brake.
    May 2015
    I'm not sure kung tama, pero yan ang ginagawa ko palagi. Basta naka-stop, shift to Neutral then handbrake kung naka-stop ang traffic light, foot brake lang kapag stop & go traffic.
    If you'll notice, kapag naka shift to D, pagrelease mo ng brake, you'll move, meaning there's torque from engine and if you relate it to physics, unused engine torque is converted to another form of energy, which is heat. Kaya para sa akin, hindi ko dapat pahirapan ang makina ng sasakyan habang mabigat ang traffic or naka-stop ako.
    Hopefully an expert can enlighten us regarding this.
    Mar 2004
2014 Honda City (Gen 4)
