Page 184 of 311 FirstFirst ... 84134174180181182183184185186187188194234284 ... LastLast
Results 3,661 to 3,680 of 8838
    Oct 2015
    Sa usapang DIY waxing
    Ano marerecommend nyo na quick hand wax?
    Yung isabay mo sa pagpatuyo after ng car wash.
    Spray lang sya then sabay na sa pagpunas nung tubig.
    May 2015
    Quote Originally Posted by coymac03 View Post
    ako nag Wash & Wax ako na shampoo, napansin ko quick dry yung ganong shampoo, chamois mo lang tapos ok na. Tapos Liquid Wax nalang.
    If tama assumption ko, kahit basa pa kotse i-sprayan narin? Ma dilute lang kase yung Wax, sayang lang. At least kung dry talaga, pure wax yung maiiwan sa last na buff mo.
    HTH
    Aug 2010
    Megs or Mothers ok yan, i have both. bango ng megs sarap inumim hehe joke.
    wag mo isabay pagpapatuyo, wash muna then dry, spray liquid wax then buff. kung gusto mo mas medyo kumintab layer mo ng QD (quick detailer)
    NEVER use ordinary towels (mayayari finish ng paint mo) use only Microfiber towels (i use chemical guys, maganda sya). sa umaga MF duster will do, i use microtex (600 petot sa ace hardware)microtex-duster_2.jpg
    Quote Originally Posted by ronmayajoan View Post
    Sir, Nabili nyo po dito sa Phil yung chemical guy?hirap kasi maghanap ng mga products ng chemical guy dito sa Phil. Thanks
    Oct 2015
    Mahal pala ng Megs, 1k.
    Any review sa ibang mas murang qiuck wax detailing?
    Natry ko yung sa may sachet ng microtex nanosliq, nakalagay sa packaging pang step 4. madulas sya after applying pro parang dumidikit parin alikabok or kulang lang yung innapply ko dahil isang sachet lang ginamit ko.
    Pwede mo sprayan ng quick detailer yung part na pupunasan mo mas madali sya matuyo at madulas tapos wax mo nlng after..
    Oct 2015
    Quote Originally Posted by cHerywinkLe View Post
    hello po. may nakaexperience na po ba dito yung ayaw magstart ng engine? i have a 2016 city vx pag start ko kanina ayaw mag on ng engine kahit naka brake naman. tas naka-on yung starter system indicator. sabi sa manual hold lang daw yung start button for 15 seconds as a temporary measure, and have it checked at a dealer.
    ipapatingin naman namin bukas pero baka lang po may nakaexperience na and ano pong cause?
    Ganyan din sa ako akin, weak battery 1 week pa lang sa akin ang unit, baka old stock ng battery nilagay, buti nga non di ko na ilong drive kundi yari ako. Pinalitan naman ng casa
    May 2015
    Does your engine cranks while you try to start it? Slow cranking or as in walang engine cranking, tahimik lang?
    Kung walang cranking, or slow cranking most probably dead/drain battery, busted fuse. Wala ka bang naiwan open na ilaw (though may alarm naman kung open ang head/tail lights). Is your car electrically modified which can cause grounded electrical wiring. Possible din na loose battery terminal. Battery lifespan as I read, nasa 1 to 2 years average.
    Kung may cranking naman, check fuel. Pero para sigurado, call you Service Advisor.
    Sa nagpalit ng busina same location mounted pa din ba pinaglagyan as to where the OEM horns are mounted?
    may nabasa ako na pinalipat nya sa bandang harap yung busina nya para masmalakas
    No sturdy place to mount horns in the grille area?
    I had the casa install the new set at the stock oem location. its quieter inside the cabin even if the new ones are
    loud.
    Quote Originally Posted by jojoR View Post
    loud.
    Bro care to share a picture?
    Thanks!
    Thanks!
    Sorry, I don't have one. I had it installed when I had my 10K pms sa casa. Btw, one of the horns are visible through the "vent holes" of the black plastic where the left foglight is mounted. I doubt if my phone camera can get a proper picture.
    What horns you installed?
    Its a denso. I forgot the model. Its a pair of small black snail type horns. It has a smaller current draw compared to stebel so no need for extra relays. I got it at P900++ at ACE Hardware.
    May 2015
    Hindi ka sinigil kase hindi mo sa casa binili? free installation?
    hope you can get the model para ma test ko rin
    thanks
    Quote Originally Posted by rabz View Post
    thanks
    rabz, originally i was requesting to have the fogs adjusted dahil masyado mababa yung bato ng ilaw. the SA verified na masyado mababa nga nung 1K PMS. dahil babaklasin naman yung bumper para ma-adjust yung fogs, sabi ko may dala akong busina, ikabit na nila. sabi ni SA yung installer na lang bayaran ko para sa kabit ng busina.
    btw, ganito yung Denso horn na tinutukoy ko.
    Another recall.
    Check if your unit is included.
    http://www.topgear.com.ph/news/indus...-cr-v-20160302
    gusto ko din palaitan ang stock horn ng amin. hindi sya nakakagulat kasi
2014 Honda City (Gen 4)
