Ano po difference ng Meguiars Quick Detailer at Quik Wax?
Mga sir ask ko lang, yung temp ba na nakikita sa right side na gauge ng VX yun yung temp ng engine or temp po yun outside the car? Naisip ko lang pano malalaman kung above the normal temp na yung engine... may indicator ba city pag maooverheat na engine? thanks!
Quick Wax is best used after every wash when the surface is clean to boost the life of your existing wax. Quick Detailer can be used to mist away light dirt and dust or as booster too after washes.
congrats welcome to the GM6. The green light is the fuel econ indicator. when it turns blue? means you ate stepping to much on he gas pedal.
Thanks. Here's the dashboard and navigation looks like on VX+ NAVI CVT. I took the picture while on parked mode so there's no fancy maps of resto, gas stations, etc.
Thanks. It's not Econ Indicator sir eh. There's a separate icon for that. This is where the green light displays on the red circle, please refer to the image below. Not really sure what does it mean, basta minsan lalabas sya when I turned left/right or hitting the gas pedal.
Front = disk
Rear = drum
Last edited by cast_no_shadow; July 3rd, 2015 at 06:27 PM. Reason: It's disk not disc haha
Weszt is right.
Green lit on is efficient driving, better fuel econ.
Blue is bumibigat apak mo, mas malakas konsumo.
I see. Thanks sir. After driving the new city for 3 straight days, I can say that the power is just right (for 1.5) even the car is full. Steering wheel is so soft and easy to maneuver, haven't tried to overtake yet though. Also, I noticed that the rear brake is drum? Cost cutting perhaps? I also get 9.3km/l for a 20 kilometers run on a city without any traffic.
What do you mean it looks different? Di ko gets.
mga sirs, napansin ko lang dun sa automatic gear stick, paglipat from N to D and D to N, hindi na talaga kailangan ipress un nasa stick? malilipat mo sya agad? Pati din R to N to D, hindi na need ipress, from P to R lang sya naglalock at need ipress un nasa stick.
normal po ba un? accidentally kasi nabangga ko un stick from neutral to drive ng hindi napress un nasa stick. tapos tnry ko na sa iba hindi nga lahat need ipress un stick.
checked the manual. mukang ganun nga ang operation nya. normal lang pala.
Normal naman talaga yun basta pabalik to neutral no need to press the button sa stick.
Pero park to reverse/drive
Reverse/driver to park
Neutral to reverse
Reverse to drive
Need to press it.
