Page 851 of 884 FirstFirst ... 751801841847848849850851852853854855861 ... LastLast
Results 8,501 to 8,510 of 8838
    #8501
    215 Mazda 2 - Page 217
    More pics<br />
    <br />
    #8502
    Wow! Very detailed explanation.
    Helpful sa mga gusto mag DIY
    Kaso not one of those guys that can DIY that
    Luckily GM6 has plenty power / cig outlets.
    No need to utilize the usb ports. No need to plug/unplug.
    Re: wire visibility clean naman yung installation nung dashcam ko, no visible wires.
    #8503
    Yung dashcam ko sa Civic hindi rin nakahardwire, malinis rin naman installation.
    Just using of the 12V ports. Yung blue wire lang yung nakalabas (haven't changed it to a less conspicuous black wire hehe), although nasa ilalim naman so hindi halata unless you're viewing it from a low angle:
    Yung sa Mazda 3 though nakahardwire yun, just to give it a try. Haven't observed any difference. You only really need to hardwire if you want your dashcam running even if your engine is off. Otherwise, personal preference nalang talaga.
    #8504
    Yung dashcam ko rin hindi nakahardwire. Just using of the 12V ports. Yung blue wire lang yung nakalabas (haven't changed it to a less conspicuous black wire hehe), although nasa ilalim naman so hindi halata unless you're viewing it from a low angle:
    12V ports! Yun pala tawag dun kanina ko pa iniisip hahaha
    Luckily Mine is black wire hahaha [emoji3577]
    Feb 2016
    #8505
    The GM/GM6 uses low profile mini fuses.
    Buy a dashcam hardwire kit that already has the fuse tap included in the kit.
    I have the kit already, at yung level ng courage at confidence to install, 10/10 naman. Hehe..
    Dashcam currently connected using the cig port sa front. Cables are neat and nicely tucked in din. Need ko lang talaga ma free yung port sa front para sa tv plus.
    Personal preference lang talaga.
    Yung sa likod mainly for charging phone lang.
    Need lang ng info if may nag attempt na sa GM6.
    Aug 2013
    #8506
    Will this fit GM6? No issues?
    pinagamit ko muna sa sister ko yung 17s mags ko kasi lakas sumabit sa garahe namin ng stock 15s (175/65R15 tires).
    Specs: 17x7.5 offset +35
    tires: 205/45/R17
    may konting rubbing sa likod, kapag puno. pero ang kagandahan, nag increase ang ride height niya ng mga more than 1/2"
    kaya kung +42 offset tingin ko no rubbing issue. lalo na kung 40 series tires.
    Jul 2013
    #8507
    quick question po...
    Possible ba na patayin yung radio ng head unit?
    Minsan kasi navigation lang kailangan ko and gusto ko sana walang music...
    Sep 2016
    #8508
    Is that blue wire included in your dashcam package? Kamukha kasi nung nabili kong extension cable para sa rear dash cam ko.
    #8509
    No it's just an extension cable.
    Oct 2017
    #8510
    hello guys share lng 2nd time na makabasa ng nasiraan ng transmission, bale sa hcvc group ko to nakita 2014 vx
    t2 — imgbb.com
    t3 — imgbb.com
    t1 — imgbb.com
    ang cause daw ung oil cooler seperator nabutas kaya naghalo ung tubig at cvtf oil, napunta sa metal belt ayun kaya daw nadurog at nasira
2014 Honda City (Gen 4)
