Results 6,521 to 6,530 of 8837
June 24th, 2017 02:21 PM #6521
Ingat sa dagta bro [emoji23][emoji23]
June 24th, 2017 03:14 PM #6522
Its not a fruit bearing trees kaya walang dagta bro.. poops lang galing sa ibon hahaha
June 25th, 2017 01:48 PM #6523
June 25th, 2017 01:59 PM #6524
June 25th, 2017 05:58 PM #6525
Nice data on the weights.
For comparison, my Civic's stock 16" rims with 215/55R16 tires weigh 44 lbs (20 kg) while my new Accord V6 18" rims with 225/40R18 tires weigh 51 lbs (23 kg).
Quite odd that the Civic's wheels are 3 kg heavier than the City VX's even if both are 16s. Didn't expect the wider tires and 5-hole patter to add that much weight.
June 25th, 2017 07:56 PM #6526
Tingin ko reasonable naman. The Civic's wheels are wider than the City's (16x7 vs 16x6). The Civic's tires are also wider (215mm vs 185mm) and have taller side walls (118mm vs 102mm). Pati ung concentration ng materials sa pag-gawa ng tires baka may factor din (silicon, rubber, plastic, nylon, etc.). Not to mention we used different weighing scales so that may be another factor too.
Sent from my E6653 using Tapatalk
June 25th, 2017 08:00 PM #6527
June 25th, 2017 08:09 PM #6528
June 25th, 2017 08:26 PM #6529
June 28th, 2017 09:10 AM #6530
mga sir ask lang ako input kung ano mas ok na engine oil sa city, due for change oil na kase ako this week and pinagpipilian ko either 5w30 or 5w40 ilalagay ko.
Ano po mas bagay sa climate natin? and malaki ba difference nung dalawa in terms of fuel economy and acceleration/engine response? ayoko kase gumamit nung 0w20 na pnopromote ng honda, masyado malabnaw na yun para sa climate natin. Btw 15k+ mileage ng gm6 ko. Baka may marecommend din kayo after market brand ng engine oil. kung mag 5w40 kase ako plan ko gamitin Bardahl, pag 5w30 di ko pa sure either motul, mitasu, mag1 or mobil1 yan kase nakikita ko na available pag nagtitingin ako. TIA!
high idle RPM at engine start
