Results 3,841 to 3,850 of 8837
November 4th, 2015 12:51 PM #3841
November 4th, 2015 03:13 PM #3842
tama ka naman sir, ok ang 0w20 sa bagong auto...pagkakuha natin ng unit pagkakaalam ko ung 0w20 na ang nakalagay na engine oil then after 6mos of use tsaka mag cchange oil...within that 6mos tingin ko and kung umabot ka na ng around 1k sa odometer di na ganun katight yung mga piston...so you can also use higher viscosity oil.
Mas malapot sir ng konti ang 5w40...and mas malabnaw yung 0w20 since 0w sya. Pag mainit na ang engine dyan papasok yung 2nd number na 20,30 or 40...the higher the 2nd number mas maganda ang heat protection. Just don't use 50 kase makapal na masyado un para sa bagong auto...usually ang gumagamit ng 50 are ung mga 2000 model below na auto. Reg sa price ng 0w20 and 5w40, same lang price nila sa honda since pareho silang fully sythetic.
- Jul 2015
- 4
November 4th, 2015 04:30 PM #3843
November 4th, 2015 05:07 PM #3844
paps. eto yung fb nung nagbebenta ng hand break bypass wire - https://www.facebook.com/richardjohn.arizabal?fref=ts
madali yan kausap and mabait.
November 4th, 2015 05:07 PM #3845
- Jul 2015
- 4
- Mar 2014
- 57
November 4th, 2015 10:34 PM #3847*dhisky Bought a pack of 4 at Ace Hardware SM Megamall several months ago. You can also try Blade.
- Sep 2015
- 76
November 5th, 2015 06:34 AM #3848Changed my stock headlight lamps Low Beam and High Beam to Philipps Diamond Vision 5000k. Much better visibility na during night drive
- Oct 2015
- 15
November 6th, 2015 08:46 PM #3849Blinking/flashing> (PNDRS),(abs),hand break. Sino po naka experience na nito 2016 hinda vct e matic ,
November 7th, 2015 08:10 AM #3850
high idle RPM at engine start
