Page 1 of 2 12 LastLast
Results 1 to 20 of 49
    Sep 2013
    Planning to buy my 1st car, seems that there are no thread about 2013 Honda City. Maybe you could post your opinions, experiences and FC on 2013 Honda City.
    Sir, ang daming discussions about 2013 Honda City dito. Just do the google custom search on the top right hand side of the page.
    Sep 2013
    Thanks sir Mguy! Mukhang hindi po gnung ka-active 2013 Honda City sa Honda Thread.
    Jun 2013
    May site dedicated solely to Honda City users sir: Honda City Club Philippines - HCCP
    Sep 2013
    Already bought my first car, 2013 Honda City 1.5E Urban Titanium A/T
    1st owner bought AUG 2013, Rizal-Laguna trip ni 1st owner & ODO reached 25K in just 17 months. so ave. daily trip is 50Km, then I bought it as 2nd hand last JAN 2015. 3X PMS ni 1st owner 5T Km, 11T Km and 22T Km (last OCT 2014).
    I would like to share some of my observations sa 1st car ko:
    1. Every time I turn the Ignition, all of the lights(even the LED cabin lamps and
    foot well) dims as if they will go off.
    2. There are times when I turn the Ignition keys, the ignition motor kicks in but
    suddenly went all off so I have to return the key to OFF and turn the Ignition
    again.
    3. Every morning or every time the engine rest for a while and I turn the Ignition
    switch rpm dial goes around 1200rpm and after 2-3 minutes it normalizes to
    800rpm, so if I change to "D" during the 1st minute the car will run at around
    10kph w/o stepping on the gas pedal.
    4. All of the lights esp. Headlamps/Fog lights dims a bit every time the A/C
    compressor turns on.
    5. Rust are forming around the break discs edges and from a complete Stop position
    when I step off the break very slowly esp on downslope roads or bridge I could
    hear a squeek-grinding like sound from the tires.
    6. During heavy traffic conditions, when I step lightly on the breaks while the gear is
    at "D" sometimes I could feel small jerks when the car is running between
    1-4kph.
    7. There are times that the gear takes time to change from 1st gear to 2nd gear and
    find it "nakakabitin" when overtaking and ended up hitting the gas pedal very
    hard and hoping the gear will shift quickly.
    8. Small vibration can be felt on the driver-side door during idle.
    Mga Honda users please share based on your experiences maybe these were all Normal or dapat ko na ipa-check sa casa.
    Thanks!
    Quote Originally Posted by Allan_2180 View Post
    again.
    1-4kph.
    Thanks!
    try to have your battery checked, baka symptoms that it is dying.
    the rust on brakes is normal, imho. moisture yan. but since it squeaks na, try to have the brake pads checked and replaced.
    #3, i think is normal.
    on the jerking and bitin sa gear shifts, palit ka muna AT fluid.
    again.
    1-4kph.
    Thanks!
    again.
    1-4kph.
    Thanks!
    i would daresay...
    1. that's normal, sir. that is why, the suggestion is, all lights and accessories be turned off before starting the engine.
    2. wear and tear? weak battery?
    3. that's normal. the "choke" is working. the engine rpm is normally adjusted to idle higher when the engine is cold. idling rpm goes down once the engine gets hot.
    4. normal or weak battery? check battery connectors.
    5. that's normal.
    6. ATF levels? replace?
    7. "hunting"? maybe it's normal, maybe #6 above.
    8. weatherstrip perished? door alignment? wear and tear on the insides of the door?
    see what 1D4LV recommends above.
    have fun.
    vibration can be from not-so-good sparkplugs and or dirty throttle body.
    About atf fluid, if its level is good, it should be good. The atf even with severe conditions will last 50k. The delayed shifting is normal imo,it's a 1.3 afterall. you're in need of an oil change. get fully synth from honda. its reasonably priced from honda.
    Jun 2015
    Ano po fc nyo sir? Ako rin po kasi bumili ng 2nd hand honda city. Overall naman okay siya. Yung fc ang tagilid. 6.1 k/l. 20k odo siya nung nabili namin. So namromroblema po ako about engine quality.
    Quote Originally Posted by proudbearer View Post
    Tune it up, to get the best fc.
    Sent from my UP+ using Tapatalk
    Oct 2015
    hi, ano ang pinakamalapad na pwedeng ipalit na gulong for honda city model 2013? ano ang mas prefer 195/50 r15 or 205/50 r15 at ndi ba sya sasayad?
    Thank you
    Oct 2015
    Thank you
    Aug 2005
    Guys...
    Balak kong palitan yung gulong ng mas malapad but same magwheels.
    Tire is 175 65R 15, balak ko po gawing 195 or 205,ano po ang maganda at tamang sukat?
    Thanks po...
    Quote Originally Posted by bhybhoy View Post
    Guys...
    Thanks po...
    185/60/R15 or 195/60/R15 sir. Pero I suggest ung 185 lang kung di mo lalaparan ang wheels sir.
    Ung 205 sir, wag ito kung naka-stock wheels ka kasi masyadong malapad para sa wheels (15x5.5" lang din ata ang stock ng GM).
    Sent from my D6503 using Tapatalk
    Jul 2015
    Anyone knows if magkano ang pedeng maging value ng Honda City after 5-6 years?
    Quote Originally Posted by carskeptic View Post
    It depends on how it was maintained, in engine, interiors, exteriors, mileage and how many times serviced in casa from the time it was bought. Honda have records in their data base.
    Sep 2018
    Hi. Tanong ko lang ko kung pano lagyan ng beep sound yung honda city 2012 kapag ila-lock/unlock yung gamit key fob?
    Sep 2018
    Tanong ko lang po kung anong led headlight yung maganda? Tsaka po yung maliwanag? Honda city 2012
    Aug 2005
    Guys,
    Meron na ba sa inyo naka experience ng mag blink yung D light sa dashboard while driving?
    Tapos hirap humatak.
    Twice ko na kase na experience yun.
    Pag ni off ko yung engine and open again,
    Nawawala naman yung blingking ng D.
    Ano po kaya problema?
    Car is honda city 2012 at.
    Thanks po.
2013 Honda City
