Results 11 to 14 of 14
- Mar 2013
- 42
June 4th, 2013 11:56 PM #11contakin nyo to sir 09159267044 ryand, may shop sya I know sa Cavite / Bulacan. Sya nakikita kong expert sa mga ECU related things based sa other forums ng Civic
- Oct 2010
- 20
June 5th, 2013 01:55 AM #12Thanks mga sir. Ano massuggest nyo na ok na casa aside sa na try ko?
Thanks sir try ko contact yan number
nagleave ako today para lang mapaayos uli
balak ko sana dalhin sa revline elite or sa isa pang casa
sinubukan ko mag research at kapareho ko ng problem mga ito sa cruise idle. Pero hindi nila mention yun jerking pag angat ng paa sa gas during momentum
http://www.8thcivic.com/forums/hondata/193985-hondata-help-required-erratic-cruise-idle-after-installing-tsx-tb-3.html
i guess nasa point na ako na nalinis na throttle body ko, at nagsasayaw needle sa 1-1.5
marunong naman ako magbasa ng mga diy, pero parang ayoko gawin ito pag hindi supervised ng may alam.
- Aug 2008
- 26
June 5th, 2013 10:01 PM #13Clean the IACV (intake air control valve), sabayan mo na rin change ng coolant - costs very cheap
Also adjust tappet clearance - madali lang din kung marunong
ECU change - nah, i dont think so
- Mar 2007
- 4
October 5th, 2017 08:42 AM #14Hi, saw your problem, how did you fix this? coz Im experiencing the same problem. thanks sir
Hondata help required: Erratic Cruise Idle after installing TSX TB. - Page 3 - 8th Generation Honda Civic Forum
marunong naman ako magbasa ng mga diy, pero parang ayoko gawin ito pag hindi supervised ng may alam.[/QUOTE]
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
