Results 1 to 10 of 14
- Oct 2010
- 20
May 22nd, 2013 12:52 PM #1Good day tsikot,
i have a 2007 1.8 fd. pag naka on ang aircon tapos nag brake, bumabagsak idle ko parang mamatayan. I think auto idle ang fd at kelangan ireprogram or relearn ang idle? Dinala ko sa casa alabang. Pinaiwan isang araw. Nag diagnostic at advise na papalitan buong computer 30k++. Hindi daw nag aayos ng ng ecu/ecm? Ano po prob nung akin? Idle lang or iba? Ano pa options ko ? Thank you
May 22nd, 2013 01:08 PM #2
Get a second opinion. It may be one or another of the sensors is dirty or the electronic throttle has an issue.
A new ECU is no joke. It doesn't make sense to replace an entire ECU if this is the only problem.
- Oct 2010
- 20
May 22nd, 2013 01:25 PM #3Thanks sir, second opinion means from a different casa or sa labas nalang? Or are there any other shops/mechanic that can do or specialize in fd ?
May 22nd, 2013 01:42 PM #4
dalahin mo bro sa servitek alabang. onti na lang naman ang distance nun from the casa eh. para madiagnose ng maayos.
baka hindi sa computer yan. baka sensors lang yan.
- Oct 2010
- 20
May 28th, 2013 01:38 PM #5Brought it to servitek pero di nila na diagnose. Pero nilinis nila servo ata? Ngayon tumataas na ang rpm naman pag nag preno. Atleast di na bumababa. Pero di padin normal. Also, pag nag ddrive, when i release my foot on the gas to coast, nag jjerk ang kotse kahit anong gear. Parang jerk sa primera pag kulang ang clutch. ?
- Apr 2011
- 27
June 2nd, 2013 04:34 PM #6
- Oct 2010
- 20
June 4th, 2013 12:29 AM #8actually sir yun naman sana pakay ko sa honda kaya ko sa kanila dinala, para learn idle, cruise idle, or throttle body calibrate. pero ang ginawa nila ay nag diagnose ng isang buong araw at sinabi na hindi sila nag aayos ng auto idle lang, kelangan bumili ng bagong computer na 30k. at inalok ako na bibilhin na lang nila yun fd ko sa mababang halaga or itrade in ko. muntik na ako sumabog
san po yun speedy fix sir?
- Jan 2011
- 317
June 4th, 2013 03:55 AM #9Binayaran mo ba yung dianosis? Kung hindi, go to another casa. it's too soon para palitan ang ecu.
- Apr 2011
- 27
June 4th, 2013 10:18 PM #10
Bossing, di lang idle learn. Ibig sabihin ng PCM update ay re-program and PCM/ECM mo (re-flashing), then mag idle learn. Sa mga Honda dealer meron nyan. Di ko lang alam sa speedyfix kung meron silang pang update ng PCM software.
Kung replacement ang solution sa isang dealer, get another opinion sa ibang Honda dealer.
When was the last time you changed them? If it's been a while, I suggest following your mechanic's...
Rubber boot question (repair or replace)
