Results 1 to 2 of 2
March 29th, 2005 12:39 PM #1
These concept cars appeared on the NY Auto Show.
The Civic Si has a " 200-horsepower, 16-valve, DOHC i-VTEC engine with an 8,000 rpm red line, mated to a close ratio 6-speed manual transmission. Helping to put all that power to the ground is a helical-type limited slip differential for improved launch traction and cornering performance. 18-inch cast aluminum wheels, 225/40R18 high performance tires and 4-wheel, with large cross-drilled brake rotors and 4-piston Brembo calipers."
No given data for the Nissan.
Both companies gave no word if these cars would be produced.
March 31st, 2005 09:07 AM #2
there is already an existing thread for this:
Honda Civic Si Concept
http://tsikot.yehey.com/forums/showthread.php?t=17383
Nissan's New Small Car
http://tsikot.yehey.com/forums/showthread.php?t=18178
closing the thread. the replies to the thread were split and merged to the abovementioned topics.Last edited by mazdamazda; March 31st, 2005 at 09:13 AM.
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
