Results 1 to 20 of 40
    Dec 2011
    Hello mga sir, gusto ko sana i-customize yung 2004 CRV ko. Balak ko sana lagyan yung interior, front headlights and wheels ko ng LED lights, tanong ko po san ba nakakabili ng LED lights?
    Jul 2011
    If you will scout the shops located in the stretch of Banawe im sure you'll find one bro.
    Unsolicited advice: Putting too much LED lights isn't very pretty.
    Oct 2011
    Quote Originally Posted by greatauror28 View Post
    you might want ot check out this thread. FYI. HTH.
    http://tsikot.com/forums/car-lights-...d-bulbs-76186/
    Hindi ko sasabihin kung saan dahil ikapapangit lang yan ng iyong CRV.
    Jan 2011
    you might also want to explore replacing your turn signal lights with LEDs. but you have to put a load capacitor to avoid hyper blinking of the lights. I installed them in my civic and the signal lights are much better than regular bulbs.
    Finally, my turn to ask. Are there any stores that sell hyper blinker Stop light? It is almost like a strobe when you first press on the brake pedal, but it solidifies after a few hyper blinks. an example of this is the tail lights of the F1 cars when they brake.
    Jan 2011
    If the lights are functional, I will disagree with your statement. However, if it's pure cosmetics, then agreed! it's like driving a christmas tree or a starship enterprise that is not.
    Jan 2011
    Quote Originally Posted by yule View Post
    use HID for headlights -- much better than LED. 6000 lumens in LED is not as bright as HID's; just my observation. I had both and elected to retain HID. Interior, make sure you get sets of fuses. I blown several when changing the interior lights. For wheels? qustionable idea, but it's your car, your style. Tsikot.com in Pamplona Las Pinas sells LED lights for plates. Di ko lang alam if they also carry festone LED lights (interior). BTW, if you happen to have fog lights, you might also want to get either HID or LED.
    Quote Originally Posted by LNopal View Post
    No, just no.
    Especially when your headlights are non-HID friendly just like what the TS has.
    Please don't encourage people to equip with HIDs as these can produce annoying glare that could possibly cause accidents, except when you have projectors.
    Jan 2011
    No, just no.
    so, you stare at the headlights of an incoming vehicle? btw, there's a headlight question from the written driving test in the philippines. you should know what is it and what is the answer for it. it is the very basic in driving.
    i am not encouraging anybody to get an HID, i am just giving him an option. how much is the guy going to get for the ordinary bulb? if he preferred the sylvnia hyperwhite, what is the difference between that one and an hid? that's right, NONE except that the sylvania is more expensive and the longetivity is shorter, plus it emits more heat than an hid, add to the fact that it is more power hungry. if the guy preferred the cheapest one, do you think that will last and will give a better lumination for dark night drives?
    there's nothing wrong having an hid if the lumens is between 3000 and 5000. they are tolerable in the eyes. exceeding that is asking for trouble. and of course, you shouldn't be staring at the headlights.
    Aug 2004
    Installing HIDs on headlights not made for them cause glare. Most of the time I have to look at the sidewalk two lanes away just to avoid getting blinded. Color temp does not count. It could be orange colored for all I care. The fact is it only goes to show that some people have more money than brains
    Go for halogens. High output ones require ceramic sockets and relays and you run the risk of burning your headlights. If you really want HID get a PROPER conversion.
    Jan 2011
    yes, it only goes to show that buying the more expensive bulb is what again? the fact that hid is more durable and less expensive shows that you are showing off to be rich? i don't get it. and yes, the color temp matters. you have the halogens which has higher wattage, that emits the same lumens will not sound practical at all. then add to the fact that you will use ceramic sockets, don't you think that's more expensive? for halogens, the higher wattage you go the brighter, and the shorter the lifespan will be. and yes, the question in the test is, where will you look at when there's an incoming traffic. when you look away, that is the right answer. and mind you, the question was written ages ago when there was no hid yet.
    Apr 2012
    T5 LED Tube supplier
    12v led lights
    flexible led strips
    Aug 2004
    use HID for headlights -- much better than LED. 6000 lumens in LED is not as bright as HID's; just my observation. I had both and elected to retain HID.... BTW, if you happen to have fog lights, you might also want to get either HID or LED.
    Ah there it is. Both pala pinagusapan natin. Where are the pics?
    Sorry pero walang deer dito.
    This is interesting to note.
    eBay Guides - Quick information on HID for cars
    If a car is not designed for HID or LED', do a proper retrofit to make it safe and unglaring!
    Feb 2005
    Which Blade shop has the best collection of LED lights? the one in greenhills closed and never re-opened and the one in Galleria and megamall dint really have a good number of brands and sizes. I just find it more convenient and less stressful than going to banawe, especially with that dang construction.
    If you are getting some better to bring the bulb you plan to replace as (maybe its just me) its hard to remember the exact size and what that converts to in LED size. Also its difficult yo find LEDs that go on the gauge.
    I considered LED since i am on stock bulbs but for some reason the socket still gets burned. I am on red LED for the brake light but tonight im going to try the white one to see if its brighter... maybe have a red and a white to really compare...
    Jan 2011
    RY, you can go buy at ebay at your own risk. just a word of caution.
    Jan 2011
    renzo, maniwala ka sa akin, meron!
    Jan 2011
    John, you are disappointing me. If you want something, do something. Make an effort. Hint: go where the car is located, I will prepare more than tuyo for santa if you want.
Where do you buy LED lights?
