Results 1 to 10 of 17
- Jan 2010
- 35
March 29th, 2011 07:50 PM #1I have a question guys.
My gf bought a second hand 2001 Civic LXi.
I'm not really a Civic guy, so I wanna know what's the best engine oil and power steering oil to use for the car.
I also want to know where is the best place to get the a/c checked?
Hope to hear from y'all.
Thanks in advance
- Jan 2010
- 35
March 29th, 2011 08:25 PM #2I have a question guys.
I'm not really a Civic guy, so I wanna know what's the best engine oil, power steering fluid and automatic transmission fluid to use for the car.
Thanks in advance
March 29th, 2011 08:30 PM #3
Kung maayos naman nakuha ninyong sasakyan palit lahat ng fluid . Engine oil, Transsmission gear oil kung manual Tranny , AtF fuid kung Automatic Tranny, Brake fluid , Flush Radiator and new coolant .Sa tune up change spark plug, air filter ,fuel filter . Check engine timing according to engine specification. I use Motul H tech 10W 40 fully synthetic sa sasakyan ko. Power steering fluid Castrol okay naman.
March 29th, 2011 08:34 PM #4
If this is the ES body Civic, have the CASA check also if the Top Dead Center sensor has been replaced (recall part). I had a similar Civic model for two years which experienced the engine shutting off suddenly for no reason at all and the culprit was the said TDC sensor; Honda only replaced it (take note, my car was already out of warranty that time) free of charge when i complained of the problem.
Since you just bought the car, change all the fluids, filters and belts.
March 29th, 2011 08:42 PM #5
There are shops like SPEEDLAB (quezon ave) and SPEEDYFIX (san juan) that can help you check the car and also help do regular PMS work on it.
- Jan 2010
- 35
March 29th, 2011 08:45 PM #6
March 29th, 2011 09:11 PM #7
They are affordable & have one of the better reputations in their field of work. Better than the overpriced service & parts and long lines at Honda casa.
SPEEDLAB: http://www.speedlab.com.ph/contact.php
- Mar 2011
- 29
March 29th, 2011 09:16 PM #8Try reading some forums at CSG. You can get some tips on how to keep your ES on tiptop shape.
http://club7thgen.proboards.com/index.cgi
- Jan 2010
- 35
March 29th, 2011 09:56 PM #9
- Jan 2011
- 317
March 30th, 2011 12:08 AM #105w-20 motor oil is the recommended oil for your 7th gen civic. stick with honda powersteering fluid if you can.
i have a theory, if the oil filter is not primed (filed up prior to installation), the initial...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
