Has anyone experienced noticing blinking "D" on their CRV? Any solution for this?
Overheated Transmission Fluid. Check Fluid at once. Drain and Refill.
Yup. Read ur car's manual. Its written there.
Blinking D means your transmission has a problem, pull over.
Problems might be
1. Overheating (no fluid/dirty fluid/lacking fluid) <- will be fixed once you drain and refill the fluid
2. Transmission computer issues <- Casa na to.
Using the car with Blinking D for long periods of time will result in a broken transmission.
Mahal ang transmission.
Worse comes to worse, tranny should be pulled down and check for gear wear and tear.![]()
Blinking "D" is for automatic transmissions located near the speedometer.
I had the same problem early this year. The mechanic said madumi daw yung solonoid which i had cleaned and it went away. Unfortunately CRV's and Accords are known for transmission problems. They have the same type of transmission, I had first hand experience for both cars 02 Accord & 02 CRV
