Results 11 to 19 of 19
- Nov 2011
- 31
- Nov 2011
- 31
May 26th, 2012 11:19 PM #13Again and again i need the masters to help me.
My car last day was overheated extremeheat kasi sinira nya cylinder head ko at marami pang part ang nasira. Now i buy all that part need to be replace even the cylinder assembly.
Now my car is running again but the day i got my car sa motorshop na pinagpaayusan ko after and half hour na test drive, the engine check lit up. So i run again to the shop kasi ala pa 1hour ganun na sya. They check sensors even the sensor of my regator fan, nakasaksak sya sa sensor but it is baypas na so they remove. Test run ulit again the check engine lit up, now they remove my intake manifold yung parang carburator they clean up sabi baka madumi daw, also all the socket of sensors they spray w40 to remove the rust daw. Pagkatapos nito we test drive again my car. Now mawala na ang check engine.
The problem is cleaning lang naman ang ginawa nila so may pag asa po pa na bumalik kaya ang engine check?
Sa takbo pala ng sasakyan ala naman nabago, the same parin.
Also my problem now is where to find speed sensor for my car. Nasira kasi putol ang gitna na paa nung socket nya.
If any one have available speed sensor on hand i willing to buy just PM me.
Speed sensor for Honda LXI PH15A engine, 1996 model and part number- 41205r15
- Sep 2009
- 30
May 28th, 2012 11:43 AM #15
- Nov 2011
- 31
June 7th, 2012 12:02 PM #16Sir i have problem with my car. LXI PH15A engine.
Mga sir ang problem nya i pagtinapakan ko CLUTCH nya tumataas RPM nya, pagtumatakbo lang naman po pero pagtigil sya maganda naman po idling nya. Pagrunning na po ako tas tinapakan ko CLUTCH umaabot ng 2rpm nya tas pagbitaw ko ng CLUTCH bumababa po ulit. Anu po kaya ang problem nun?
- Sep 2016
- 5
September 18th, 2016 09:31 AM #17Mga Boss magkano kaya aabutin pagawa front at rear bumper ko may punit siya konti at repaint nadin?
- Jul 2008
- 10
September 21st, 2016 08:47 PM #18boss, had the same problem before(96 vti). after changing all bushings (front & rear) including stab links, ball joints & tie-rod ends, may tumutunog pa rin. finally had the steering box adjusted, ayun nawala! parang bago na naman!
- Oct 2009
- 2,271
September 21st, 2016 09:00 PM #19sa evangelista ako naka bili ng brandnew replacement plastic only walang paint.3.2k ang kuha ko harap likod.ikaw na mag pa paint,...
about nman sa lagutok.na solve ko din ung sa akin.ang problema ay ung pinaka washer niya sa shock maluwag na siya.ung washer na nilalagay sa shock tapos ung shock cover (tabo) saka ung shock mount niya .at wag masyadong higpitan ung nut sa ibabaw pag ikot ng pinaka ehe ng shock sa pag higpit ok na..
I don't feel any diffeence ng DCT Sent from my iPhone using Tapatalk
(2023) Ford Territory
