Results 41 to 50 of 174
April 15th, 2021 05:24 PM #41
You know what, now that I’m looking at it more and more, the design reminds me of 90s cars. A little bit boxy, small grille and those long singkit headlights. You know, those late 90s galants, accords, etc
April 15th, 2021 05:28 PM #42
Pang Fafa Boi na talaga [emoji16]
Sent from my Mi A1 using Tsikot Forums mobile app
April 15th, 2021 05:32 PM #43
Top model subcompacts na yung 1M price range. Compact cars are over 1M nowadays.
If your mindset is stuck in the early 2000s, you will never consider buying a compact car for over 1M or a midsize car for nearly 2M. I guess a Vios or City will be worth it if your limit is 1M.
BTT: I don’t mind the looks as it shares the same general look of the recent Civics. As long as it drives well, it gets my vote. I do hope they make turbo engines standard for all models.
Sent from my iPhone using TapatalkLast edited by Egan101; April 15th, 2021 at 05:34 PM.
April 15th, 2021 05:38 PM #44
April 15th, 2021 05:50 PM #45
- Mar 2014
- 690
April 15th, 2021 09:06 PM #46I like the rear of this new civic. Sa outgoing kasi gusto ko yung front but not the rear.
- Dec 2019
- 2,072
April 15th, 2021 09:09 PM #47
April 15th, 2021 09:47 PM #48
Nope. The current R18 is rated 139hp at 5500rpm and 174Nm at 4000rpm. Honda’s 1.0L turbo used on the Civic is rated at 127hp at 5500rpm and 200Nm at 2200rpm. It may be down a bit on power but it offers more usable torque (at less than 3k rpm).
Most people don’t drive their Civic 1.8L at over 4k rpm (on a regular basis) so they don’t make to good use the peak torque of the R18 engine. With the smaller turbo gas engine, more torque is always welcome at around 2k rpm.
With the exception of the Civic Type R, Accords use more potent engines compared to the Civic. They usually drive better and quicker off the line. There’s a reason why Accords cost more than a Civic, the same as an Altis can never be a Camry.
April 15th, 2021 09:56 PM #49
April 28th, 2021 03:08 PM #50
high idle RPM at engine start
