Page 6 of 12 FirstFirst ... 2345678910 ... LastLast
Results 101 to 120 of 233
    Apr 2008
    #101
    Quote Originally Posted by albert_b View Post
    sige sir, I'll try to take a picture tonight.
    Btw, would you know sir if the Mobile XT application itself can be upgraded?
    i really dont know but my uncle has garmine mobile xt in his iphone 4 may mga updates siya.
    it will be nice kung ma pipicture mo yung accuracy thanks
    by the way try moving the car while getting the accuracy. minsan kasi 10m then pag linipat mo ng puwesto maraming satellite ang mag lolock in kaya tataas ang accuracy mo from 10m will go to 4 . pero sa iphone kasi ng uncle hangang 10m lang talaga
    Apr 2010
    #102
    tried pressing the signal meter located at the upper left part of the screen while on GPS mode.. it showed elevation and speed of travel, on the left side it showed the same circle drawing with blips with numbers.. im assuming those are satellites..
    on the right side are some slightly moving bars, around 7 to 10 of them... but i didnt see any number of meters for accuracy.. sorry im at work today, cant show the picture I took from my camphone.. maybe tommorow when I get home from work.
    Apr 2008
    #103
    Quote Originally Posted by olidotcom View Post
    thanks sir in advance. paki post po thanks
    Feb 2011
    #104
    Sir pwede ba yan sa City 2010?
    Sep 2004
    #105
    I got the same as si Oli. No accuracy pero from my use ok naman siya. I've never been placed in the wrong place (as long as may satellite signal ofcourse).
    I tried to use the other facility outside of the Mobile XT and this is how it looks naman
    Apr 2010
    #106
    ayoowwn! ganyan na ganyan din sakin! ahihihihihi!
    #107
    Quote Originally Posted by jedi View Post
    we are installing the head unit to another nissan livina owner
    thanks sir sa unit!! baliktad lang kabit sa camera pero dali lang naman ayusin yun. also, ok yung fix niyo para sa radio antena...
    #108
    i tried putting a different garmin xt sa unit ko. check ko maya kung me accuracy na makikita. as for the map itself, talaga bang parang split yung screen sa right side? hindi kasi buo eh, im trying to look for a fix. also sa GPS din, pag nag type ba kayo or search anong keyboard ang lumalabas? wince kasi yung akin eh, nung nagpalit ako ng garmin xt saka ko lang napalabas yung keyboard ng Garmin.
    btw, how do i change the boot logo?
    TIA
    Sep 2004
    #109
    :-) Those are what Oli and I are also trying to figure out.
    Apr 2010
    #110
    yep... same issue on the right part of the screen.. since garmin xt is for windows ce or cellphone use only.. medjo malaki laki yung monitor natin.. so malamang.. yun ang side effect. hehehe..
    #111
    Question please for those who bought the lightning lab unit with GPS:
    1) Regarding GPS, where did you put the antenna (little black box)? on top of the dash or under the dash (behind the radio)? I've been using the unit for almost 1 week now and the only time I've gotten a GPS signal was the first day I had the unit installed, from then on, I haven't been able to get a signal, not once...I'm thinking maybe I should put the antenna on top of the dash, what do you guys think?
    2) Opening logo...anyone find a way to change this? I really thought you can customize the opening greeting / logo, gusto ko sana brand nung car ko, para it looks OEM, hehe
    Thanks in advance.
    Sep 2005
    #112
    *oli
    sir thanks po sa reply nyo sa PM
    sir ask ko alng po anong format ba kaya iplay ng lcd na to, un mp4 kaya pero what format and un avi ganun din, un iba na pplay yun iba hindi :D
    sana magawan natin ng solution un gps, sakin din hirap kumuha ng signal e :D
    #113
    Quote Originally Posted by kalirayacs View Post
    *oli
    Sir...san po naka-lagay yung bluetooth antenna nyo? sa ibabaw ng dash or sa ilalim ng dash (inside the hole for the Head Unit)
    Thanks.
    #114
    Quote Originally Posted by chongklc View Post
    Thanks.
    bluetooth is built in sir, if you are referring to the gps antenna and tv antenna, yung sa gps sa bandang side nilalagay sa loob ng panel ng sasakyan left or right side, tv antenna sa taas na windshield
    Sep 2005
    #115
    Thanks.
    may antenna ba yun blutoth?
    alam ko wla ehh :D
    un gps nilagay ko na ngayon sa taas ng dash :D dati sa ilalim, wlang makita na satellite
    #116
    alam ko wla ehh :D
    Sorry, that's what I meant, yung GPS black box...so kahit sa taas ng dash wala pa ding satellite connection? by the way, nung nilagay mo sya sa ibabaw ng dash, saan mo pinadaan yung wire?
    Thanks in advance.
    Sep 2005
    #117
    Thanks in advance.
    sa gilid lang po sa mga singit singit hahaha :D
    d ko pa nttry since nilipat ko sa dashe hh, later tonight :D
    #118
    there were times na kahit nasa loob sya ng dashboard ok pa din signal... pero mas maganda pa din sa bandang taas... madali lang ilinya yung wires sa gilid para mailagay sa taas, dun rin dinadaan yung wire ng tv antenna.
    #119
    GPS antenna ko sa upper right windshield ko pinakabit katabi ng TV antenna for better accuracy.
    Sep 2005
    #120
    sir ano po ba ok na converter, kasi wlang nag pplay na music video sa HU ko
    un mga galing you tube, mp4 format na, tapos coconvert ko ng avi ayaw pa din
2din HD DVD TV GPS Rear Camera
