Page 5 of 12 FirstFirst 123456789 ... LastLast
Results 81 to 100 of 233
    Oct 2008
    #81
    Quote Originally Posted by olidotcom View Post
    sir, is that a wallpaper (yung nasa likod ng icons) that you placed yourself, or is it just a reflection ng pagka kuha niyo ng pic? parang picture kasi ng isang interior shot ng isang car, yet it also looks like something else. ano rin po pala balita sa customized greeting logo and wallpaper?
    budget na lang hinihintay ko. aww...
    Apr 2010
    #82
    Quote Originally Posted by Burai View Post
    yes sir, what you see is correct, its a wallpaper of a car (parang hinati yung side body nya para makita yung loob..
    unfortunately i havent seen any option to change that one. the only wallpaper that I have changed dito sa unit is when before I play a DVD/mp3. na save ko yung picture/logo na gusto ko. after that wala na.
    Oct 2008
    #83
    so does that mean para siyang psp nga na nakikita mo yung wallpaper? i mean, nasa background siya habang nagpi-play yung mp3 without pressing any buttons anymore just to view it. yung tipong 1 time go lang sa settings then lagi na siya available makita whenever you play mp3? pwede sample picture sir if hindi naman nakaka abala sa inyo? hehe thanks
    Apr 2010
    #84
    hi sir, sorry, Im not sure what you're talking about.. wala kasi akong PSP.
    anyway here's the picture when playing MP3 on usb mode.
    this is the first view for USB / SD Card / TV / DVD modes.
    the one that is different is the part of the right side, you can see in the picture is the list of my music in the USB. that will automatically maximize palagi. whatever mode you are in.
    if im going to play DVD that one is different, the logo/picture that I saved is the one first going to show.. then mag play na siya ng DVD.. mawawala na yung logo/picture
    #85
    Mazda Tribute po kinakabitan namin today
    #86
    does this read FAT32 formatted SD cards and USB?
    Apr 2010
    #87
    Quote Originally Posted by edricdude View Post
    yup! using kingston 1 gig and 8 gig USB sticks fat32 formatted. sd card 2 and 8 gigs.. same format.
    Jan 2010
    #88
    Quote Originally Posted by jedi View Post
    Pakipost naman pix ng Tribute. Halos pareho lang ang panel nito with Ford Escape. Thanks.
    Sep 2004
    #89
    Upgrade the maps :-)
    Garmin Mobile XT ang gamit natin.
    Apr 2008
    #90
    Quote Originally Posted by albert_b View Post
    sir pa check naman yung accuracy ng garmin kung ilan. nag iisip kasi ako na ang kunin ko yung walang gps kasi meron na ako garmin 255w with 4m accuracy. pero gps is lot nicer in big screen
    Apr 2010
    #91
    Quote Originally Posted by clickaway View Post
    afaik regarding accuracy, its the same but unfortunately Garmin XT is not anymore being updated by Garmin... but you can still update the maps and supplementary maps.
    originally the one installed in my unit is Garmin XT version 5 which is the last one updated by garmin. tapos yung map copy came from roadguide.
    (not sure what version) but i believe accuracy is also within 5 meters/less
    I also downloaded a supplementary map and overlayed it together with the primary map on the headunit and it worked just fine. (more detailed street maps/names and POI's)
    Feb 2011
    #92
    Sir Jedi, puede po ba to ikabit sa 2011 glx strada?
    Apr 2008
    #93
    the reason im asking of the accuracy because of this photo. yung car kasi wala sa road.
    im also a member of roadguide.ph and i always contribute and get my updated maps there. can you please check the accuracy of the garmin while the car is moving. you can do this by pressing the signal bar. kasi sabi sa ibang nabasa ko forum, garmin mobilehais 10m accuracy.
    ito nalang kasi ang pumipigil sa akin pag bili.
    by the way does it have a gps external antenna?
    thanks
    Apr 2008
    #94
    thanks
    #95
    thanks
    yes sir may external gps antenna... na pwede ilagay anywhere sa kotse as long na abot yung wire. im not really sure dun sa accuracy if its 5m or 10m
    #96
    using garmin mobilext on win ce, i compared the reception of my head unit sa gps ko sa N8, everytime na nagpupunta ako sa tanay area, pababa ng antipolo sa may teresa area, 2 to 3 times napuputol signal ng gps sa N8 ko, sa garmin ko sa head unit, never pa ako naputulan sa area na yun.
    Sep 2004
    #97
    The reason my car is not on the road is because I'm parked inside a lot :-)
    Accuracy is good (I don't have the exact figures lang) pero you need good antenna placement din.
    thanks
    #98
    we are installing the head unit to another nissan livina owner
    Apr 2008
    #99
    sir if you just can press the signal button for 3 to 5 sec it will show you how accurate is your gps. like this one..
    its really really important to me the accuracy medyo related kasi sa work ko. thanks
    Sep 2004
    #100
    sige sir, I'll try to take a picture tonight.
    Btw, would you know sir if the Mobile XT application itself can be upgraded?
2din HD DVD TV GPS Rear Camera
