Results 1 to 10 of 17
- Feb 2015
- 633
July 6th, 2015 02:21 PM #1What is the correct/proper motoring etiquette when it is raining hard?
Park lights on? Headlights on? Hazard lights on? All on?
I'm confused if I should turn my hazard lights on because other drivers might think that I am in an emergency or having troubles with my car even though I am not.
July 6th, 2015 02:27 PM #2
July 6th, 2015 02:59 PM #4
Some basics:
1. No hazards. Use your headlights.
2. Slow down and keep more distance from the vehicle in front (5 seconds instead of 3).
3. Slow down for puddles and be mindful to pedestrians and other vehicles.
Some basics:
July 6th, 2015 03:15 PM #5
Ang for those who are available - always be on the lookout for a damsel in distress...
"Sadya bang
Swerte swerte
Lang pag
Umuulan; Noon
Pa lang
Ako naabutan
Ng suwerteng
Ganoon; Hawak
Ko ikaw
At ang
Payong mo
At kahit
Ulan ay
Tumilang bigla
May nangyari
Ng Hiwaga!"...
BTT: Turn on your AC and use your wipers, please!..
26.9K _/_/_/_/_/:cat:_/_/_/_/_/
July 6th, 2015 03:17 PM #6
tail lights are more than enough to see the car in front of you even in heavy rains, if you fail to see the car's tail lights in front of you you have poor eyesight, move to the side of the road (if you can) where its safe to stop and wait for the downpour to subside, this time you may turn on your hazzard lights to let other motorists that there's a car (in distress) on that side of the road...
July 6th, 2015 03:22 PM #7
I turn on my HIDs (stock) but since the light is daylight white, I also turn on my fog lights (para mas makita ng ibang tao, esp Pedestrians). I turn off my foglights at night though because I am sure it glares oncoming motorists.
I only go as fast as I can see but leave room for emergency braking/swerving. You'll never know what might surprise you.
Always do an emergency brake test. Go fast then brake abruptly. So you can drive accordingly and adapt to your tires' grip. That's why never scrimp on tires. Nakamura ka nga sa chinese fake tires, nabangga ka naman kasi nag-slide ka. I use Continental on my sedan and Bridgestone/dunlop on light truck. Check your tires specs and get the one with highest grip (traction) grade, also max velocity, temp, expiration.
Always, Always look around. Observe your surroundings, the street you're passing by on and other vehicles.
Please don't use hazard lights in a downpour. I used to be a stupid idiot who practices that before when I was a newbie.
Safe driving!Last edited by Horsepower; July 6th, 2015 at 03:25 PM.
July 6th, 2015 05:57 PM #8
July 6th, 2015 07:12 PM #9
Fog lamps that are designed to have a short and wide beam dispersal; thus properly aimed lamps with the proper bulbs are not really supposed to blind fellow motorists.
^ Ako I just use the good ole mini elm327 OBD2 scanner. Pero usually sa long drives ko Lang...
