Results 1 to 10 of 35
August 15th, 2014 05:45 PM #1
Sino dito ang nagmamaneho ng mga automatic vehicles? Mayroon ba kayong restriction code 4 sa license niyo? ako minsan nakapagdrive ng automatic at naisip ko na wala akong restriction 4 sa license kaya kinakabahan ako baka masita ako, pero hindi naman ata mahigpit itong pinatutupad. Kaya siguro madami din ang mga aksidente involving automatic cars tapos ang sisisihin nila ay 'sudden unintended accelaration' na sa totoo lamang ay driver error dahil sa kakulangan sa kaalaman sa pagmamaneho ng automatic na sasakyan.
Restrictions:
Restriction 1 - Motorcycles/Motorized Tricycles
Restriction 2 - Vehicle up to 4500 kg Gross Vehicle Weight
Restriction 3 - Vehicle above 4500 kg Gross Vehicle Weight
Restriction 4 - Automatic Clutch up to 4500 kg Gross Vehicle Weight
Restriction 5 - Automatic Clutch above 4500 kg Gross Vehicle Weight
Restriction 6 - Articulated Vehicle 1600 kg Gross Vehicle Weight & Below
Restriction 7 - Articulated Vehicle 1601 kg up to 4500 kg Gross Vehicle Weight
Restriction 8 - Articulated Vehicle 4501 kg & above Gross Vehicle Weight
http://www.cebuliving.com/images/hos...e/pidlrear.jpg
August 15th, 2014 06:22 PM #3
Its a Restriction, if you have number 4 it means you can ONLY drive Automatic Transmission up to 4500 kgs.
August 15th, 2014 06:47 PM #4
- 54,207
August 15th, 2014 06:47 PM #5restriction 2 allows you to drive AT or MT, up to 4500 kg.
restriction 4.. walter is right. you are allowed to drive only AT, up to 4500 kg. you are not allowed to drive MT.
restriction 1... is it true, it may be given on a whim, without benefit of evaluation? because if it is true, then that explains why there are so many mis...
August 15th, 2014 07:05 PM #6
August 15th, 2014 07:31 PM #7
Dini discuss po yan ng taga LTO bago ka isalang sa driving test. If you have restriction 2, pwede ka na mag drive ng MT and AT.
Tama yung explanation ni Walter pertaining to restriction 4.
Sent from my Windows Phone 8 using Tapatalk
August 15th, 2014 08:28 PM #8
The operative word is "RETRICTION". It prohibits you from doing something beyond what you are licensed for. So if you have restriction 4 in your license then you are RESTRICTED to driving an automatic vehicle up to 4500 kg. You may not drive a manual and/or a vehicle above 4500kg gross weight.
On the other hand if you have 1 and 2 you are restricted to driving motorcycles and vehicles above 4500 kg gross weight. It does not restrict you to doing anything else, so it means you can drive both a manual and an automatic.
Restriction 4 is for the handicapped, like if you have use of only 1 good leg. You can not drive a manual if you have only 1 good leg can you? So you are restricted to driving an automatic because you only need 1 leg to drive it. People who lost a leg, a polio victim or suffered a stroke fall under this category. People with decreased physical abilities, like the elderly, also fall under this category.Last edited by yebo; August 15th, 2014 at 08:35 PM.
- Jan 2013
- 143
August 15th, 2014 08:59 PM #9
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
