Results 1 to 20 of 31
    Jul 2004
    Ano ba ito: 1 hurt as shuttle bus falls from Skyway | Inquirer News
    Mahina ang railing ng Skyway ah
    It really makes me wonder if something really is wrong with the design or sturdiness of the railings at Skyway.
    the railing is not weak.. its the design of the railings.. if you take a good look at the railings, it seems high enough to prevent vehicles from falling over. unfortunately there's that cement curb sticking out from the bottom of the railing serving as the base of the railing.. i think once the tire hits that part it lifts the vehicle high enough that with enough momentum a car or a bus can actually be thrown over the railings. can someone else explain in easier terms what im trying to say.. if anyone understood what im trying to say.. heheh
    Basically, the proper design for the bottom of the curb at the railing is a slope angled up to catch the vehicle and redirect it back onto the road. Dunno why they don't do that since: a.) there is no sidewalk, anyway, and b.) they already have the forms to copy, in the portable barriers they use:
    Alternative would be a low-profile barrier like so:
    The idea is not to catch the bus or truck, but to push it back by redirecting the force of impact. If you have a vertical surface to catch the vehicle, it will simply accept the brunt of the impact and collapse if the vehicle is heavy enough.
    As you can see... the Skyway has very square kerbs.
    The upgraded portions of the SLEX now use properly designed barriers for the median in some areas:
    Woe to you if you should fall off the shoulder, though...
    I've tested these barriers already (on the Buendia - Kalayaan/Fort ramp). A stoned driver cut into me (yes, he hit me on my side door already) and i nudged the barrier. My tires went up and down the angled portion. There was no severe damage save for the dent caused by the stoner. PDR and wheel alignment fixed all.
    Here's the video of that incident, it seems like the driver of the Fortuner was drunk or fell asleep behind the wheel.
    http://www.abs-cbnnews.com/video/nat...r-falls-skyway
    Sep 2009
    Why does it seem to be that the identity of the driver of the Fortuner is witheld? While the name of the coaster is mentioned.
    When I look at the video, to me, it appears the Fortuner swerved, bumped into, and caused the coaster to lose control and fall off the skyway.
    Aug 2013
    Quote Originally Posted by ano727 View Post
    Nabibili media sa atin, ganyan din sa mga malls. Maraming hindi nababalita dahil nag suhol. Tulad noong Ondoy, may mga nalunod sa loob ng mall pero hindi nila ibinalita. Ganyan rin doon sa aksidente sa batang nahulog sa escalator, hindi binabanggit sa TV yung pangalan ng mall.
    Sent from the Twilight Zone...
    Jul 2011
    Quote Originally Posted by e2romo View Post
    Ang mga media sa atin ay talo pa ang attorney, nakunan na sa cctv ung mga magnanakaw at identified, ibabalita pa din na ang nahuli ay suspect sa pagnanakaw, para bang umaasa na pag pinanood ulit ung cctv e pwede pang maiba ung ending.
    just want to comment, parang OT cguro to.. but i just get annoyed when a mini bus is called a coaster...why cant it just be called a mini bus.. a coaster is a mini bus made by toyota, a mini bus Rosa is mini bus made by Mitsubishi, a county mini gus is made by hyundai. a civilian is a mini bus made by nissan. a combi mini bus is made by Kia. anyways just ranting. heheh.. but i think the MINI BUS that fell off the skyway, is a hyundai county.
    Na pit bump yung coaster kaya nag 90 degree diagonal sa barrier. I dont think those barrier are design for that. They are design for low angle side bump.
    Apr 2010
    Is it true that this accident happened exactly at the same area wherein Don Mariano bus fell off? Kung totoo man, nakakakilabot!
    Sent from whatever device I got my hands on via Tapatalk
    Jul 2011
    Quote Originally Posted by monkeybone1k View Post
    If this is indeed true, then it is apparently a coincidence.
    But you cannot avoid that some believers will claim this as some sort of misfortune brought by some paranormal being.
    Jun 2004
    Different areas, this was near Sun Valley before Bicutan exit, the Don Mariano accident was another 3 kms south.
    Mukhang bata pa yung driver ng black fort...
    SUV in Skyway accident overloaded: police | ABS-CBN News
    Jul 2004
    Coaster ng Skyway pala ang nahulog
    How ironic
    Quote Originally Posted by cocoy View Post
    That's the power of marketing and brand recall, and Toyota is second to none in the Philippines when it comes to brand recall.
    Just as people say Xerox instead of photocopy, or Pampers instead of diapers, people also say FX instead of AUV and Coaster instead of minibus.
    I suggest you just let it go, or you'll end up crazy. Baka sa susunod ikaw na tumalon sa Skyway niyan 😁
    Posted via Tsikot Mobile App
    Jun 2011
    IMO mahina and not properly designed ang railings na ginamit dyan.. it should be higher and sturdier...
    sa dami dami ng nalaglag dyan... kitang kita naman na parang walang tibay yan railings na yan...
    its not serving it purpose...
    Ganyan nga. May department talag ang mall at mga buildings na ang trabaho ay ayusin ang mga ganyang problem. SO malamang ang family ni fortuner e ganun din ginawa, pinagana nga pera para sa privacy nila.
    IMO, both events had the bus crashing perpendicular to the railing. I don't think those railings were designed to catch that. I would think a heavy wall would be solution to this but unfortunately that is just too cumbersome and expensive to set up.
Another bus falls off the Skyway
