Results 41 to 50 of 57
November 17th, 2008 01:26 PM #41
yup relatively newbie driver here, pero definitely working on my clutch driving sickness hehehe i can say i've learned a lot from this forum and this thread mismo. I'm improving on a daily basis dun sa pag bitaw ng clutch, even though may times nahuhuli ko sarili ko nakatapak
i also noticed an improvement in my FC. Thanks guys!
November 17th, 2008 01:57 PM #42
Me also. I see to it na tanggalin ko muna yung cellphone ko from my pocket, bago ko i-start yung kotse. Once kasi while driving, at nasa pocket ko yung cp ko, may tumawag. Habang kinukuha ko yung phone, nawala ang concentration ko sa road. Muntik na ako madisgrasya.....whew!
At sa akin, pag pa-atras ako, automatic yung pag-on ko ng hazard lights, lalo na kung palabas ako sa isang parking slot.
And, bago ako umusad.....sign of the cross.Nakasanayan ko na.
November 30th, 2008 12:00 PM #43
1. clean the car in & out
2. clean engine bay and check water, oil, atf, brake fluid, power steering oil.
3. check tire pressure.
4. shower na & bihis
5. start engine to warm up
6. turn on aircon blower with compressor "off".
6. check & align sight for all mirrors
7. set radio station/ cd and desired volume.
8. press central lock.
9. go na after all the above.
10. turn on compressor once temp needle is elevated.
11. start bad mouthing stupid drivers on the road!!! hahaha...
- Oct 2008
- 8
December 4th, 2008 03:56 AM #44bagong driver lang din ako, in fact nagaaral pa nga ako sa driving school, bagsak nga ako sa clutch eh, kasi ang pagkakaintindi ko "LAGI" kang tatapak sa clutch pagnaka first gear ka, lagi pang namamatay ano po ba ang tama?
1. Press clutch
2/ Shift to first gear
3. slowly release after pressing on the gas pedal.
4. then i stay semi pressed on the clutch
tama ba? thanks po dami kong natutunan.
December 4th, 2008 06:47 AM #45
December 4th, 2008 10:22 AM #46
December 4th, 2008 11:56 AM #47
babagsak ka talaga. kasi you are pressing still on your clutch.
dapat pag stop ka release to N, then engage only on 1 when you are ready to move.
and another thing... uubusin mo prematurely ang clutch lining mo pag di mo binago yan, plus tatakaw ka sa FC
the correct way is only up to # 3
do the #4 if you want to burn-out your clutch!
December 4th, 2008 02:11 PM #48
- Oct 2008
- 8
December 5th, 2008 02:50 PM #49*alwayz_yummy
thanks! so after na car is moving release ko na totally yung clutch right? Yun din pagkakaintindi kaya lang mukhang di kami nagkaintindihan eh. hehe
December 5th, 2008 04:01 PM #50
clutch driving is bad for your wallet and car hehehe.. kung moving na yung car, DO NOT rest your feet on the clutch kasi kahit lightly pressed lang yan, slightly engaged yung clutch mo ending up in power loss which could lead to inefficiency in fuel consumption and premature clutch burn-out.
YD’s Super DM-I Technology Efficiency Test | Better Than A Bicycle? AutoDeal
BYD Philippines
